Windows 10 - Resolume Stalling Out
immanent_vj
Post by immanent_vj »
Is there a recent Windows 10 update that prevents Resolume from working properly? I've got two different laptops and a desktop all running Resolume 6 (various versions) and they're all experiencing the same thing. Application stalls, videos won't load, I end up force quitting the application. I've done some clean Windows 10 installs to temporarily fix the problem, but it keeps coming back and driving me crazy. Help?
Re: Windows 10 - Resolume Stalling Out
Could you send us the Resolume log files?
It's in C:\Users\[username]\AppData\Roaming\Resolume Arena
Does this happen right after re-installing windows 10, and trying to load files?
I mean like in the same 10 minutes?
Thanks for the log.
Doesn't seem to contain much info.
Did you already remove Sonic Suite from this Asus machine?
You could try updating your graphic drivers, and if that doesn't help try renaming the Documents/Resolume Arena 6 folder.
