Problem with Aja Kona 4
ncuz
Post by ncuz »
Hi, I currently using Resolume 6 with Aja Kona 4 as capture card device.
PC Specification: i7 6700k, 16GB RAM, GTX 1070 and Evo 860 SSD
I'm having trouble with the input, when I'm check with the AJA software, there is no problem with all input and the quality. But when I'm trying to use with the Resolume, 1080 50i image appear like drop frame (jaggering) and the 1080 50p wont detect. The clip setting using auto detect format and I can't change it. Also trying to change hardware buffer and deinterlace, but 50i still jagging.
Any solution with this? Thanks
Re: Problem with Aja Kona 4
Could you contact us via the feedback tab in preferences with your log file?
