feedback
SuperficiaL
feedback
Post by SuperficiaL »
hi guys,
props on 2.3!
when u drag the feedback source effect on a clip when there are no clips playing, and than dragging the feedbacked clip to channel(F1,F2,F3) makes the framerate of that movie and all other movies u play after that rise to 100, when i then lower the framerate it goes back up to 100 again...
greetz and keep up the good work,
SuperficiaL
P4 3.0 HT
1024 MB Ram
ATI Radeon 9800 pro (128MB)
win XP sp1
huh? i do not quite understand what you are doing. what do you mean by 'dragging the feedbacked clip to channel(F1,F2,F3)' ? do you mean a layer? but it,s impossible to drag something to a layer.
please explain some more ;-)
SuperficiaL
k
drag the feedback effect over any clip when there are no clips playing...now press that movie to play the movie in one of the 3 layers... than the slider of the framerate 9automaticly) goes up to 100 and everytime i try to lower the framerate by dragging the slider it just goes up again...
hope this helps...
greetz SuperficiaL
DAS BEN
Post by DAS BEN »
i think feedback should be used on an empty place in the deck and then on a layer at the top.
