Resulume arena with BlackMagic Decklink 4k Extreme 12G
meshal
Post by meshal »
Hello all,
Does BlackMagic Decklink 4k Extreme 12G works with resolume arena perfectly? cause I want 4k SDI input and 4k SDI output, or there is an alternative for this card?
Thank you!
moha20106
Re: Resulume arena with BlackMagic Decklink 4k Extreme 12G
Post by moha20106 »
Resolume supports Blackmagic capture cards
I'm already have 2 mini recorder cards and working as well
deflost
Post by deflost »
we have two of the 12g extrem in one xeon computer. works perfect. no problems with the last three resolume releases. bevor some cases with signal dropouts.
r.h.
westfernsehen, leipzig
lightbx
Post by lightbx »
Just checking in to ask whether these cards keep all SDI outputs in sync? I've read here before that Blackmagic SDI outs do not always keep sync, curious if that is specific to when BMD cards are secondary cards (for additional outputs), not the render card.
Would running a Blackmagic card as the primary GPU perform better with syncing signal across outputs?
A capture card is not a GPU so that won’t work.
drazkers
Post by drazkers »
lightbx wrote: Sun Jan 13, 2019 03:18 Just checking in to ask whether these cards keep all SDI outputs in sync? I've read here before that Blackmagic SDI outs do not always keep sync, curious if that is specific to when BMD cards are secondary cards (for additional outputs), not the render card.
The outputs are not synced or good for edge blends.
