Optimising for an extended output with 4K content
newfuturenow
Post by newfuturenow »
I have a set that requires an output of 7680 X 1080, some of the video content has been provided to me by the organisers to map to the stage and is a resolution of 3840 X 2160 /4K. The content will require a lot of slicing to fit the various LED screens.
What do you think would be best - To rearrange and re-export the 4K content via AE to fit the pixel map and the 4 pixel map outputs of 1920X1080 in After Effects. Or to create a composition of 7680 X 2160 in Resolume and work with slices in the advanced output panel?
I have a 2018 macbookpro that I havent had the chance to test at a resolution of this size, I am not sure how it would handle a composition size of 7680 X 2160, which is considerably more than 7680 X 1080.
Would it make that much of a difference, if realistically I am only using 7680 X 1080 of the display space?
Re: Optimising for an extended output with 4K content
7680 X 1080 is the same amount of pixels as 3840 X 2160.
I'd do the re-arranging in a 4k composition in Resolume and the Advanced Output.
Is your other footage for the event 7680 X 1080?
newfuturenow
All the content is a mix of HD and 4K. So can I import 4K video as my content and use a composition setting of 4K and then slice this up and output it to a different size (e.g. 7680x1080) ? Is that correct ? I had always beleived that my imported video had to fit within the output display resolutions.
He2neg
Post by He2neg »
Yes,
You can slice it up in every way you want. Biger, smaller, to different outputs etc etc...
https://resolume.com/support/en/input-m ... n-led-wall
~Berlin~
I see what you did there
He2neg
Post by He2neg »
Joris wrote: Tue Jan 15, 2019 20:53 I see what you did there
I dont :P :oops: :mrgreen: :ugeek:
~Berlin~
