REAL SETUP CONFIG BITWIG + RESOLUME 6 with LINK
yfchild
Post by yfchild »
Someone see a tutorial how setup bitwig to send music to resolume 6 and animate clips? I´m looking for in youtube and don´t find really a video that´s explain how do it?
Bitwig connect with Resolume but i don´t see how i can syncronze audio with video.
Someone can help me and put the step by step.
thanks.
Re: REAL SETUP CONFIG BITWIG + RESOLUME 6 with LINK
You would need to setup your output source in your DAW to be the input source for External FFT in Resolume. The you can use External FFT to animate your parameters.
yfchild
Post by yfchild »
Hi Arvol. Thanks to answers. 2/3days days I´m looking for that.
Can you explain more the steps, you know something like that " 1/open preference in bitwig, choose
2/active link etc." or some captures if you can.
many thanks to answer. I try to undersdand what you write now.
Example 1:
Laptop 1 has Focusrite 2i2 Interface. DAW sends output to 2i2 output L&R. The 2i2 has a Y cable installed on the output. One side of the Y cable goes to house audio, The other side of the Y cable goes to Laptop 2's audio device IN port.
Laptop 1 has Focusrite 2i2 Interface. Resolume selects the 2i2 input 1 as external FFT control. This laptop's audio interface IN is connected the Laptop 1's audio interface OUT.
DAW plays music, Resolume receives music. You now can select parameter animation to use external FFT. and the amplitude of the audio will animate parameters. You can fine tune the EQ and Gain per parameter.
Example 2:
Only 1 laptop.
Install a virtual loopback adapter like soundflower or virtual Cable and then route an aux out of your DAW to this virtual adapter. In Resolume select the virtual adapters output you used in your DAW. Have your master out in your DAW go to your house audio as normal. All the steps above would then follow.
If you're note sending audio out to anyone other than Resolume, the use the following example:
In your DAW select your speakers out and use that as your input in resolume for your External FFT.
yfchild
Post by yfchild »
HI Arvol,
first. Big thanks for your time.
I´m with windows with a only new station machine, but i don´t think problem. I think I M THE PROBLem ;)
I install LOOPMIDI. And create virtual Bus as you said. I see them in resolume and resolume. I try with midiclock, ableton link, and change/test how i can. The same thing, only something happen but only wiht bpm sync
I attache some capture I did:
https://ibb.co/pwj1R0k
https://ibb.co/qnGQsmL
https://ibb.co/hKXhshs
https://ibb.co/SnG1nC6
https://ibb.co/ZVLFg5J
Best regards and, again, thanks for your time. I really appreciate your help because I need so much that.
So External FFT is audio, You are connecting your DAW via MIDI. MIDI is not audio (per-say) MIDI is digital values that controls instruments and other things.
Try looking into Soundflower. You have the right mindset, you're just using the wrong protocol :)
Do exactly what you just did, but do it using Soundflower and Audio this time rather than MIDI.
yfchild
Post by yfchild »
Arvol,
Thanks a lot. I have it at final ;)
Very happy now I ´m setup ableton+bitwig+arena together for some test with jackaudio and resolume react with external fft .
