Multiple Videos to Multiple Outputs simultaneously
tcash5679
Post by tcash5679 »
I want to use one midi trigger to trigger two separate video files to go to two separate outputs simultaneously. can it be done?
Re: Multiple Videos to Multiple Outputs simultaneously
Yes, this can be done a few different ways.
One simple way would be to make your composition as wide as all your outputs together.
Then in the Advanced output, create screens for all your outputs, and position/size the input slices to the area of the composition you'd like the screen to sample the texture from.
Then in the composition you only need to position your content to these areas with the clip or layer transform.
