Projector Warping / Stacking Help (Best Practice)
nknapke11
Post by nknapke11 »
Hello!
I've been stacking 2 projectors (for output) making duplicate slices for each of the projectors, then warping the outputs for alignment.
I've been pretty happy with the results. (It fits my need, as the 2 projectors are different resolutions and doing a manual/physical alignment of the pixels is not possible in my situation. )
However... this is a really lengthy process when making lots of slices.. (Making a slice on projector 1.... transforming the output to map the object... then making a slice on projector 2 .. transforming the output to map the object.. then warping one of the slice outputs to align with the other projector)
In a perfect world... I wish I could do the alignment warp ONCE... and then treat the wrapped pair as if it is one projector.
So i could just make slice and map it... but resolume would would send the slice to both projectors (that have been warped together) Is there a way of doing this? I feel like I might be missing a simple solution.
Re: Projector Warping / Stacking Help (Best Practice)
Is this what you’re after:
nknapke11
Post by nknapke11 »
Yes! This is perfect!
I'm guessing this is only a features of Arena 6. (I'm currently running Arena 5)... Thus why I couldn't find that option?
nknapke11 wrote: Wed Jan 23, 2019 16:03 Yes! This is perfect!
Virtual displays as input for slices is broken in 5.1.4, but it works in 5.1.3. You can get them from our download page.
Scroll down on the page, you'll find version selector comboboxes, which have most previous releases.
Select the one you'd like and your download should start.
