Resolume and AMD Ryzen 5
enzo.verhoeven
Post by enzo.verhoeven »
Hello everyone
I am currently intrested in building a system for basic resolume use in small venue's with max 2 outputs.
I stumbled on the following configuration:
-AMD Ryzen 5 2600X - Processor 3,6 GHz 6 core
-Crucial BX500 240 GB - Solid state drive
-Corsair Vengeance LPX 32 GB
-Gigabyte B450 AORUS PRO motherboard.
-Gigabyte GeForce GTX 1050 Ti OC 4G
How does Resolume response with AMD processors and will i have enough power to get the things done?
And also is the graphic card strong enough?
Many thanks
Enzo Verhoeven
Re: Resolume and AMD Ryzen 5
I don't think there's any issues CPU wise. A higher base clock speed vs more cores is preferred. A good SSD and GPU is next. How much more would a GTX1060 run compared to the GTX1050ti?
enzo.verhoeven
Arvol wrote: Sat Jan 26, 2019 01:35 I don't think there's any issues CPU wise. A higher base clock speed vs more cores is preferred. A good SSD and GPU is next. How much more would a GTX1060 run compared to the GTX1050ti?
Hi Arvol
Thanks for the reply. Do you mean the comparison performance wise between GTX1060 and the GTX1050TI ?
Cheers
Enzo Verhoeven
Empyfree
Post by Empyfree »
I think Arvol meant “how much more expensive is the 1060 compared to the 1050”. Worth spending as much as you can once, rather than regretting it later on.
