1 Large Fixture over Multiple Lumiverse?
WaypointAV
Post by WaypointAV »
Background, we're making custom LED panels. Each panel is 21 x 21 nodes. That's 441 total nodes, 1323 DMX channels, making 3 universes per panel. This will be driven by the AlphaPix Flex controller from HolidayCoro, which outputs to 340 pixels per output. So each panel will require two outputs.
What I'm having trouble with now is figuring out if, within Resolume, I can make a fixture profile for the panel that would span over three universes. Is there another way to do this?
Re: 1 Large Fixture over Multiple Lumiverse?
Fixtures in Resolume can't span over multiple universes currently.
We know this sucks, and are looking into what we could do to improve this.
What you can do now would be to create smaller fixtures in Resolume and place those to fill the area you'd like to get their input from. Then you'd need to set the pixel block start addresses accordingly in the Pixel driver's settings.
