Hide mouse cursor on 2nd display
- rawdesigns
Can’t seem to find a setting to hide mouse cursor in external monitors in Windows 10. Please help. Thanks!
Re: Hide mouse cursor on 2nd display
Outputs on the secondary displays are essentially borderless windows, so hiding the mouse cursor is not possible over them currently.
What you could do would be to move the first external screen to a position in the OS display arrangement settings, where only the corners of that screen and the GUI screen touch.
This would minimize the cursor being able to move to the secondary displays in the first place.
To be completely clear, we do hide the mouse cursor as long as Resolume is the app in focus. The moment you switch to another app, there's not much we can do about the mouse. Because you just told your computer that we're not in control anymore.
If you're using Resolume normally, you will never see your mouse on the output.
Should you see your mouse on the output, you just need to click. Even when your mouse is on the secondary display, Resolume will regain focus, and hide the mouse.
- rawdesigns
It’s the only app open and yet I still see a mouse cursor. Is there some setting I’m missing?
- rawdesigns
i see now it only shows up if im sliding a parameter (like xy) from clip properties, it'll show up on 2nd monitor
