Spout input + effect = black output
Nackgi
Post by Nackgi »
I'm having a problem with spout input and some effects. (Newest version of Resolume)
When I put for example a hue rotate effect on top of my spout input source, the output goes all black. Same happens at least with levels, infinite zoom and iterate. Some effects work just fine. And every effect works if I use a video file as source instead of spout.
Anyone else having this problem?
My spout input comes from TouchDesigner as 8-bit fixed (RGBA), changing the format didn't help.
Re: Spout input + effect = black output
Do you have the latest drivers for your GPU?
Also, what kind of GPU are you using?
Which Resolume version are you using exactly?
Nackgi
Post by Nackgi »
Seems that the problem was with the gpu driver. I installed the newest WHQL-driver and everything works again.
It's just strange that I had the same problem with my desktop and my laptop, with different GPUs and (probably) different drivers. My desktop has 1080Ti and laptop 1070. I don't remember the previous 1080Ti driver version, but laptop has 417.22 installed and at least it has this problem.
