I have a top layer with various flashes and strobes that I want to basically leave at 100%, then be able to hold a button and have the strobe play for only as long as the button is held, I want the clip to eject once I'm done holding the button.
Currently the button (on my Akai APC40) is assigned to play the clip directly, and thats all fine, but I need to change it so it only plays while pressed.
How would I do this?
Triggering Clips only when button is held?
Re: Triggering Clips only when button is held?
Change the trigger style to “piano”
