Colour picker out OSX format
fred_dev
Post by fred_dev »
Does anyone know the data format and types that the colour picker uses over OSC? When I analyse the message I see the type is 'r'. I want to send the info to my won software made with openframeworks, and I cannot decide this message. I can use the RGB sliders to send a colour, but the RGB values do not update when the colour picker is used. It would be great to be able to access this data easily. I am guessing it communicates fine between resolume systems, but talking to other things is also nice.
Cheers
Fred
Re: Colour picker out OSX format
You can find the supported OSC type tags here: https://resolume.com/support/en/osc#type-tags-and-range
OSC color values have the type tag r followed by an unsigned integer representing a 32 bit RGBA color. You can write a color as an int by bitshifting its RGBA values.
edwin
Post by edwin »
I just checked and the openframeworks OSC implementation supports Color messages.
ofxOscArgRgbaColor
https://openframeworks.cc///documentati ... RgbaColor/
