Serato video not available + sync
jaydeeshow
Post by jaydeeshow »
I know there is a similar thread but it’s not clear and not exactly my issue.
I use to see Serato video output in resolume 5 now I can’t see it in sources.
Differences: I’m using last updated resolume 6 and Serato video from Serato DJ Pro.
Hopefully you can help finding the sources.
After this if someone can explain how resolume can follow the bpm from Serato feed using a pioneer Ddj sx2 controller, there’s a lot of confusion.
Thank you if anyone can help.
J.
Re: Serato video not available + sync
jaydeeshow wrote: Tue Feb 26, 2019 03:59 I use to see Serato video output in resolume 5 now I can’t see it in sources.
Can you see the Serato output in other apps, like OBS?
jaydeeshow wrote: Tue Feb 26, 2019 03:59 After this if someone can explain how resolume can follow the bpm from Serato feed using a pioneer Ddj sx2 controller, there’s a lot of confusion
Can Serato output Midi clock? https://resolume.com/support/en/midi-sh ... midi-clock
jaydeeshow
Zoltan, sorry but I don't know what is OSB.
Not sure about the midi clock on serato.
Empyfree
Post by Empyfree »
jaydeeshow wrote: Tue Mar 19, 2019 22:47 Zoltan, sorry but I don't know what is OSB.
OBS, https://obsproject.com
I assume the texture sharing output in Serato has to be enabled manually.
Have you done that and do you see it in other applications, while it's not showing up in Resolume?
jaydeeshow
No, the feed doesn't show even in NDI. I've ticked and unticked almost everything. Lot's of useless troubleshooting.
If it's not working in other programs either, you might want to contact Serato about this.
