hey champions!
I'm a newbie v.j fro australia- who has just got into vjayin (im a film maker by trade)
I am usin resolume 2.2 and i have a few questions!
I don't know a whole lot about computers, and i am tryin to best set up my sony vaio for vjayin
It plays o.k, but if i use any effecys on the layers, or mix more than two images at once it slows down and creates some lag!
my specs are:
sony vaio pcg k66p
2.8ghz
512mb ram
64mb video card
It is my only computer so it also has all my other programs and files goin
Is this o.k?
how can i make it run smoother?
Thanks soooooooooooooo much guys
an aussie loves ya work!
hardware question
continuity-B
continuity-B
I say firewire, I'm not sure why your's drops out bunny?
This is for the reason you gave bunny, all usb ports basically share thier bandwidth so if you are using other usb devices, you are reducing the available 480mbps bandwidth for the drive.
Firewire on the other hand has a constant transfer rate of 400mbps all the time.
My advice is get an internal drive and stick it in a caddy with BOTH firewire and usb2 connections (these cost little more than single connection type caddys) that way you can experiment at virtually no extra cost or risk.
Also keep your eye out for firewire800, the new version of firewire with 800mbps transfer (you will likely need a firewire800 pcmcia cardbus too) or external SATA drives with a whopping 1500mbps transfer rate (need SATA pcmcia cardbus). These are more expensive and harder to find solutions at this time though.
