fisheye-correction plugin?
mortenstensland
Post by mortenstensland »
Hello
We have a wide-lens camera that we would like to correct for fisheye. Is it an easy way to fix that using Resolume?
gpvillamil
Re: fisheye-correction plugin?
Post by gpvillamil »
Not sure if this what you need, but looks promising: https://github.com/DanielArnett/360-VJ/releases
Are you looking to un-fisheye your image?
mortenstensland
yes I would like to remove fisheye. Ive looked at the 360 plugin-bundle but it doesn't include fisheye to flat correction
lightbx
Post by lightbx »
I’m shooting from the hip here, but GoPro Studio is a free software with a fisheye correction feature. Of course, it’s designed for the GoPro camera and may not be as flexible as you need, but it’s free.
sucker? lol
dradutu
Post by dradutu »
try this
Fisheye.zip
(168.81 KiB) Downloaded 1373 times
only tested the 64 bit one but i included a 32 bit as well. i made .46 the default which seems to work best for full hd comps. .50 is no distortion*. for other scenarios remember that it matters if you place it before or after Transform.
*i meant no correction
also, check the thread for the ffgl2.0 version. posted aug 13 2019
Babcom
Post by Babcom »
Oh I would Die for this to! Im creating a show at the moment where this tool would make my work so much easier to handle... Is there a Mac version of that perhaps Dradutu?
dradutu
Post by dradutu »
sorry windows only
Babcom
Post by Babcom »
I see. I guess I will need to wait for this to be a Mac thing as well... Sad that PC FFGLs aren't easy to convert to Mac. It would be a neat tool to have.
mortenstensland
just tested the 64 bit plugin on windows pc and it seems to be perfect for the job! great job. however for the particular project im working on the director doesnt seem to mind the fisheye-after all, so no correction will be needed this time. but great to know that the solution exists.
