Crashing midi out to loopmidi/xbox
Grimm90
Post by Grimm90 »
Not sure if this is a problem caused by resolume or the external midi apps.
I've connected my xbox controllers to ocean swift controller to midi app , which outputs to loopmidi , into resolume.
It happened a couple of times now i'm setting up , and i click "midi in" , no problem.
Out of habit with my apc40 , i often click on "Midi out" too on the loopmidi port, but then resolume freezes completely.
No crash / crash report but it's frozen solid, i need to use task manager to end it.
Re: Crashing midi out to loopmidi/xbox
Enabling midi output from Resolume to the midi port you get input to Resolume will create a feedback loop.
So you launch a clip, that's sent out via midi to Resolume to launch the clip, so the clip is launched, and sends out a midi note to Resolume to launch the clip....
Grimm90
Post by Grimm90 »
aight makes sense , so its just a nono don't touch that thingie
You can touch it if you want, but be aware of the consequences ;)
Midi output to a non physical device is usually not a good idea if you also have input enabled from it.
