Whenever i start a FX clip with Goo , it seems like the effect always first goes to a sort of "max" state before it like normalises... I use goo with very low settings (speed 0.05 , XYZ 0.02 aboutish) , but when the fx clip is started it will go in "overdrive" for a second or 2 before stabilizing to the subtle settings.
Which is kinda annoying , anyone have the same or am i freaking out here ?
Goo effect
OnlineZoltán
- Team Resolume
Re: Goo effect
Do you place these subtle settings from an effect preset?
OnlineZoltán
- Team Resolume
Re: Goo effect
Thanks, Grimm90,
I've been able to recreate what you describe. We'll see what we can do.
