Not to make money with, back to 2.0
Anonymous
Post by Anonymous »
American VJ in China touring Nanjing, Beijing and Tianjing for Coors Light. Two and a half week tour going great using Resolume but 2.3 just set me back a bunch. Should have waited before uninstalling 2.0.
SPECS -
Pentium 2.4 Ghz
160 Gigs HD (Don't know how to find out the RPM can you help?)
Raedon 9550 Pro 256Mb
WinXP SP2 (With a backup 2 backup OS, SP1 & out of box)
EQUIP -
Panasonic GS-NV400 3CCD Camera
Philips Tuner Input Card (Composite, S-video & TV)
Creative SB Midi & 5.1 Digital Sound Card
IEEE 1394 DV Input
KAWAI Midi Keyboard
M-Audio Oxygen8 USB Keyboard
8 Channel Video Amplifier
TFT/VGA to Composite/S-Video converter
*** PROBLEMS WITH RESOLUME 2.3 ***
I've been using 2.0 with no problems but now I have these.
1) Long, long startup time, very bad for a club situation if a reboot
is needed or short setup time. May not be fixable. Set all uneeded services to manual and turn off all uncecessary processess but still slow.
2) Clip list with thumbnail. In 2.0 it thumbnails and lists the clip thumbnail real fast when searching file directories but real slow in Resolume 2.3
3) Dragging clips stops output. Dragging a clip into the deck stops (slows to 0%) the clip from playing but then starts again when the clip is 100% loaded in the deck. This makes it impossible for me to use resolume!!!
So the biggest problem I have is that I can't pick files out easily and place them in a deck while VJing. The only workaround is to have decks premade before shows, but when I vj I have so many clips that I build decks as I vj and save the cool ones I made.
If you know any other solutions to this please let me know. 2.3 has awesome features I'd love to use while on this tour. I'll have a 3.5 month gig in a little bit and would love to be using 2.3.
Robert
continuity-B
Post by continuity-B »
You know you can still get the older versions here in the downloads section?
just in case you didnt
