Preview Monitor - custom bg image?
jonoevans
Post by jonoevans » Sat May 04, 2019 22:03
Is it possible to customize the background image of the Preview Monitor?
One of my venue's LED panels are split apart into columns- often times I need to display peoples' names on the panels and it would make my life a lot easier to preview the text spacing against a background grid to see if it's in alignment with the panels.
Thank you!
jonoevans
Re: Preview Monitor - custom bg image?
Post by jonoevans » Sun May 05, 2019 11:20
Would this feature be useful to other people?
He2neg
Post by He2neg » Sun May 05, 2019 22:17
Soo... You have a Clip (text effect) and typ something and then want to see if the text is were it should be....
i would try to set my clip the way that its allways at the same place and i dont need to worry about this anymore...
either
use the transform tab of the clip to place / scale the clip to be were it should be
or
take a whole Layer (& Layer to slice) and place the Slice in the advanced output were you want it to be.
But there might be some reason why you dont want to do it that way and i want to hear them
Laptop: XMG P507 // Intel i7-5500 / GTX-1060 / 1tb SSD / 32gb RAM // Touch OSC / Lemur/ APC-40
~self employed AV technician / Schu.VT@posteo.de~
~Berlin~
francoe
Post by francoe » Tue May 07, 2019 02:24
You can use a bypassed group with two layers (text + bg) and preview the whole group mix.
Then drop the text clip to the 'live' layer.
francoe
Post by francoe » Tue May 07, 2019 02:33
A simplest one: load your BG clip (columns and so), apply a crop and make a preset.
Then use that preset with your text clips to fit the content on that crop.
Turn it off when it's ok.
Post by Joris » Tue May 07, 2019 08:47
+1
