Help to communicate Resolume with JavaOSC
gmccosta
Post by gmccosta »
Hey,
I'm using JavaOSC to build a java application to send OSC messages to Resolume.
At the Resolume preferences, I can see the messages are coming correctly, but the clip didn't start playing, can anyone help me?
Code: Select all
String myIP = "192.168.1.108";
        int myPort = 7000;
        OSCPortOut oscPortOut;
        Thread oscThread = new Thread();
        try {
            oscPortOut = new OSCPortOut(InetAddress.getByName(myIP), myPort);
        }catch (UnknownHostException e){
            return;
        }catch (Exception e) {
            return;
        if(oscPortOut != null){
                Object[] thingsToSend = new Object[3];
                thingsToSend[0] = 1;
                OSCMessage message = new OSCMessage(myIP, thingsToSend);
                message.setAddress("/composition/layers/1/clips/1/connect/composition/selectedclip/connect");
                try{
                    oscPortOut.send(message);
                }catch(Exception e){
Re: Help to communicate Resolume with JavaOSC
The address should be either
or
The first will always connect the layer 1 column 1 clip, the second one will connect whichever clip is selected.
