Resolume and Dante Virtual Sound Card
elgarf
Post by elgarf »
Can't get DVS into Resolume in ASIO mode.
Here is log:
INFO: Changing audio setup to:
INFO: Device Type: ASIO
INFO: Output Device: Dante Virtual Soundcard (x64)
INFO: Input Device: Dante Virtual Soundcard (x64)
INFO: Samplerate: 48000
INFO: BlockSize: 480
INFO: Failed to apply audio settings, trying to open default setup
INFO:
INFO: Error connecting to Dante Virtual Soundcard Manager
INFO:
INFO: Device didn't start correctly
It works ok in Premiere Pro though.
Re: Resolume and Dante Virtual Sound Card
Is the device in use by any other app?
elgarf
Post by elgarf »
No, I don't think so. There is no another ASIO apps running.
Do the settings in Resolume match with what are set int he DVS control panel?
elgarf
Post by elgarf »
Same setting is only "buffer size". Tried same values and differrent with no luck.
Does it work in Windows Audio mode?
elgarf
Post by elgarf »
Yes, at least it set audio device to DVS (I can't listen it right now).
Do you have a Dante Clock master in your network?
I couldn't get DVS working in ASIO mode without a clock master either. Once I started Dante VIA on another machine, Resolume could select the DVS ASIO input.
elgarf
Post by elgarf »
Nope. I'll try it later.
elgarf
Post by elgarf »
Looks like it doesn't work if no channels assigned to the device. With Dante AVIO interface all ok.
