RESOLVED: Denon Prime and FX on videos
Sifu
Post by Sifu »
My issue with the video clip has been resolved (Video needs to be the length of the song)
However, I am experiencing a few other issues:
1) None of the FX are working
- Adjusting the eq has no effect on video
- the fader just cuts the video out abruptly, rather than fading it
- the hpf/lpf knob do nothing in the video
2) Can I apply audio reactive effects in resolume to a clip and have it react live to what is playing within the denon players?
Thank you!
Re: Denon Prime and FX on videos
Sifu wrote: Wed Jun 19, 2019 00:14 1) None of the FX are working
Currently Resolume uses Denon StageLinQ to get timecode and fader information from the players.
If you'd like to use mixer controls to control Resolume, try connecting the mixer to your computer via USB / midi.
Then you should be able to create Midi shortcuts as explained in this article: https://resolume.com/support/en/midi-shortcuts
Sifu wrote: Wed Jun 19, 2019 00:14 2) Can I apply audio reactive effects in resolume to a clip and have it react live to what is playing within the denon players?
Yes, but you'd need the actual audio as input to your computer:
https://resolume.com/support/en/paramet ... o-analysis
Sifu
Post by Sifu »
Zoltán wrote: Wed Jun 19, 2019 14:38
Ok - this resolved my problem.. Connecting the x1800 to the computer running resolume.
Thank you!
This will be my next dive. thank you!
