Problem apc40 mk1
omrinile
Problem apc40 mk1
Post by omrinile »
Hey,
I have a problem with my controller.
That I turn it on (even before I plug it in with usb) have flickering soom buttons.
In addition, if for example I press the first button on the top right, it activates the lamp with the right button. That's how the whole controller functions as well as knobs.
I connect the controller to the resolume the controller working good, but still have the problem
Does anyone know how to solve this problem?
Thank you,
omrinile
Re: Problem apc40 mk1
omrinile wrote: Fri Jul 19, 2019 15:55 That I turn it on (even before I plug it in with usb) have flickering soom buttons.
Sounds like a hardware issue.
Does the color feedback work from Resolume?
omrinile
Post by omrinile »
Even if I connect only to this electricity, it flickers to me.
Try contacting Akai support, maybe they know a solution for it.
omrinile
Post by omrinile »
Thanks a lot, I'll try
