Help or advice needed on precise editing of short video clips
ianpeel1001
Post by ianpeel1001 »
Hi all. I'd really like some very short video clips - like of handclaps or bass drum kicks, for example.
I'd like to edit them very neatly, perhaps crop/'green screen' them too, so i can trigger them in piano mode over the top of other clips.
But I can't seem to get the start and end points edited precisely enough using Filmora. Any advice?
Using Resolume Avenue 6 here, on a Asus TUF FX705d.
Re: Help or advice needed on precise editing of short video clips
You can set the clip start/end points quite nicely in Resolume: https://resolume.com/support/en/video#timeline
