Report Midi Crash and Translate ?
Snoxxx
Post by Snoxxx »
Hey,
2 day ago in a pre-show my Resolume 7 crash when i re-map midi button midi desk 1 to midi desk 2. Input midi are good, clip start but midi out are always map on desk 1 with template desk1. I change to midi out desk 2, and the template midi out are on desk 1 for color. Need to clean and re-map, not switch.
And SMPTE sync, all great work but in menu arena>préférence>audio > Title : Input Timecode SMPTE2 are 1 and Title: Input Timecode SMPTE1 are 2, maybe in translate to french?
https://nsa40.casimages.com/img/2019/09 ... 874465.png
ok done =)
Re: Report Midi Crash and Translate ?
Snoxxx wrote: Sun Sep 08, 2019 19:02 And SMPTE sync, all great work but in menu arena>préférence>audio > Title : Input Timecode SMPTE2 are 1 and Title: Input Timecode SMPTE1 are 2, maybe in translate to french?
Thanks for letting us know, we'll look into this.
Snoxxx wrote: Sun Sep 08, 2019 19:02 my Resolume 7 crash when i re-map midi button midi desk 1 to midi desk 2. Input midi are good, clip start but midi out are always map on desk 1 with template desk1. I change to midi out desk 2, and the template midi out are on desk 1 for color. Need to clean and re-map, not switch.
Does Resolume crash often, trying to re-map a midi shortcut?
Did you see the crash reporter dialog pop up after the crash, and were you able to send the crash report with it?
