Arena 7 Takes 15 seconds of frozen after every button press
alstergee
Post by alstergee »
since upgrading to 7 BOTH 6&7 hang every time i push ANY button regardless of amt of clips, composition size, frame rate, bit depth, effects, etc ive tried literally everything. i reformatted and reinstalled windows / latest updates & drivers and still same damn problem im running a system with 7th Gen i7 / 64GB DDR4 RAM, 1080Ti, and 2TB NVME as main hard disk.
ANY testing, solutions, fixes, or at least a RESPONSE from resolume would be appreciated i tried sending a support email and got nothing in return
Re: Arena 7 Takes 15 seconds of frozen after every button press
alstergee wrote: Sun Sep 08, 2019 23:53 since upgrading to 7 BOTH 6&7 hang every time i push ANY button regardless of amt of clips, composition size, frame rate, bit depth, effects, etc ive tried literally everything. i reformatted and reinstalled windows / latest updates & drivers and still same damn problem im running a system with 7th Gen i7 / 64GB DDR4 RAM, 1080Ti, and 2TB NVME as main hard disk.
What kind of files are you using with Resolume?
In your email you wrote Resolume 6 works fine for you, has that changed?
We answered your email on aug 29th, and also your crash reports earlier.
If you didn't get them, you might wanna check your spam folder ;)
deflost
do you use midi yoke?
Post by deflost »
hello. do you use midiyoke as a virtuell midi port router?
if, then completly uninstall it restart and try again!
loopmidi is the best replace for it, if your problem get solved with replace midiyoke.
we recognize it as the break with the atem control software from bmd and all versions of resolume bevor 7.
perhaps is somethimg with the gui programming and/ or the midiyoke resources.
good luck,
wf, l
westfernsehen, leipzig
