Arena reject onboard Line-in and mic-input
moha20106
Post by moha20106 »
Hi all,
I have to work with line-in music comes from the Mixer over AUX jack, conneted to my PC
When i trying to set the input audio in preferences, the resolume reject to use line-in or mic-in options
After choose it, its going to choose (no audio) automatically
It can choose Blackmagic audio-input
But refused my line-in and mic-input options
Any idea how to fix it
Re: Arena reject onboard Line-in and mic-input
could be either https://resolume.com/support/en/audio-input-no-worky
or the sample rate of the input and output audio devices not matching.
You can check this in the windows audio device preferences.
moha20106
Post by moha20106 »
Zoltán wrote: Fri Sep 13, 2019 08:30 could be either https://resolume.com/support/en/audio-input-no-worky
Thanks Zoltán for your support
The problem was with the sample rate in audio devices, it was 41000
Now it working fine
Thank you again
