Advanced Output Issue — Input Selection not displaying in Output Transformatio
second.seasons
Post by second.seasons »
Hello,
I’m having an issue where my input selection is the test card but the output transformation window only displays a light grey background. No matter if I add something into a layer, use the test card, or load an image background for the screen, resolume seems to default to displaying this solid color as my slices. I can switch to full screen display to show the input source but when I use advanced output my input selection is negated no matter the content. How do I fix this?
Re: Advanced Output Issue — Input Selection not displaying in Output Transformatio
Sounds like your GPU doesn't meet the minimum system requirements: https://resolume.com/software/specs
Theatre sound engineer, photographer, programmer, aka ravensc.
VJ footage: https://goo.gl/58oHy7
second.seasons
Zoltán wrote: Mon Sep 23, 2019 19:39 Sounds like your GPU doesn't meet the minimum system requirements: https://resolume.com/software/specs
These are my Mac specs
We're also in contact about this via mail right?
pfelberg
Post by pfelberg »
Hello.
This is happening to a friend of mine here as well.
Do we have an update on this matter?
It is a RTX 2060 32gb GPU
This was an issue with intel GPU-s only and has been already fixed in 7.0.4.
Please ask your friend to contact us via the feedback tab in preferences with his log file ;)
