Looking for 5-6 outputs nothing fancy or even close to 4k
vonshavingcream
Post by vonshavingcream »
My graphics are low fi and retro so lower quality actually makes it look more fitting.
To give you an idea right now I am running everything off a surface laptop with a dell 3100 USB docking station.
I get 4 external plus the surface display.
It works but there are wires everywhere.
I'd like to move to a less cumbersome solution for travel and setup. So I was hoping to add a rack mount PC to my road case.
Can anyone suggest a 5 or 6 port graphics card that could get me going in the right direction?
My main large display is a 1080 50'
And the others are 720.
Thanks in advance.
Chris
He2neg
Re: Looking for 5-6 outputs nothing fancy or even close to 4k
Post by He2neg »
You also can think about the Solution to run high res outputs and split them with aditional Hardware into seperate screens...
Datapath Fx4 / Tripple Head to go / Club 3D are the most common tools for that.
~Berlin~
crv74
Post by crv74 »
You can put a Quadro P4000, a sync2 and a Blackmagic Quad2 (with 8 SDI bidireccional in/out) and sync everything together with a simple SDI black burst.
Then you can have 1x 4K for control, 3x 4K to split (with Datapath for example) or whatever, 8x SDI full HD for entertainment ;)
Seems that Quadro for processing and Quad2 for outputs works nice, and if you don't need the sync, you can save some money too...
