Is it possible to use the output from another program and have it as a live feed?
mcstrepta
Post by mcstrepta »
Hey guys,
I was wondering if it is at all possible to use the main video output from another software program (in my case I want to use the output from serato video) and have that come into resolume as a live feed that I can play on a layer so that I can mix videos in serato video so that everything is nice and in sync with the videos, but that I can then use resolume to add other layers over the top as well as do other video mixes for songs that I dont have video clips for in serato vj. I will be running them both through the same computer so was wondering if this was possible. Would make playing live a whole lot easier with more things running in motion with each other without my constant manual input. Thanks for your help.
He2neg
Re: Is it possible to use the output from another program and have it as a live feed?
Post by He2neg »
yes you can.... spout, ndi, syphon (mac) are some tags you can find what you need...
~Berlin~
