Installation Error in Resolume Arena
MATZOUTI
Post by MATZOUTI »
Hallo to all of you,
i am a new member in the Forum and in general i am new in Resolume. So i am happy to be here :D
I am trying to install Relolume Arena the latest version Resolume_Arena_7_0_4, and it gives me an Error message :
"Cannot create directory for the Resolume DXV Adobe plugins Installation will be aborted"
I have installed the adobe suite in the same driver, but again i have this message.
Is something more i have to do??
Thank you for you time !!
Re: Installation Error in Resolume Arena
Great to have you here ;)
Try exiting all Adobe programs before starting Resolume installation.
Max
Post by Max »
Hey guys,
I have the same problem with Resolume_Arena_7_0_5.
All Adobe Programs are closed and I'm on directory C:.
Any solutions for his? Need help!
Cheers
Try creating the folder manually: C:\Program Files\Adobe\Common\Plug-ins\MediaCore\7.0\
and re-install Resolume.
Max
Post by Max »
Just tried that. Sadly also not working.
Also tired to install "Resolume_DXV_Codec_3_0_1_Installer.exe". Nothing happening.
Max
Post by Max »
Short info: I already had DXV on my computer and I had to reinstall all Adobe programs.
After that the DXV export option in Premiere and AE disappeared, that's why I try to reinstall Resolume now.
Which AE version do you have?
Max
Post by Max »
AE 2020 Version 17.0.0
Max
Post by Max »
Also now reinstalled older versions of Premiere and AE.
Also not working
Ok, could you send us a screenshot of the error message you get?
