7.0.5 and .mp4
Snoxxx
7.0.5 and .mp4
Post by Snoxxx »
Hello,
I see you have add "NVIDIA Application Profile" on 7.0.5
I have 170fps on DXV and 3fps on .mp4 on one layer ? :? WTF ? (Normally is 60fps with many layer, many output)
Help please, what is change?
Re: 7.0.5 and .mp4
Mp4 playback is broken for some reason in 7.0.5
We're looking into it.
I'd recommend to convert to DXV for best performance, but if you don't want to, 7.0.4 should play mp4 better (forwards at nominal speed)
You can get the installers for the older versions from our website.
Go to our download page, and scroll down.
You'll find version selector comboboxes, which have most previous releases.
Select the one you'd like and your download should start.
Snoxxx
Re: 7.0.5 and .mp4
Post by Snoxxx »
Thanks Zoltan faster as light, i try to re-instal but same.
I try to change my test.mp4 on DXV with Alley and it's very clean and fast fps like before maybe better; speed and forward play are good smooth but 80Mo -> 5Go … erf i with i do buy new disk if y do all change. And 2nd problem, on work on stage, sometime :lol: , all time? :o One Artist come very late for adding media, 80% is .mp4
Snoxxx
Re: 7.0.5 and .mp4
Post by Snoxxx »
If you tell me DVX are best i listen, i need the best for resolume. :D
Re: 7.0.5 and .mp4
Snoxxx wrote: Wed Nov 27, 2019 20:12 Thanks Zoltan faster as light, i try to re-instal but same.
Did you re-install 7.0.5 or 7.0.4?
Snoxxx
Re: 7.0.5 and .mp4
Post by Snoxxx »
7.0.5 before reed mp4 are broken in 7.0.5
Re: 7.0.5 and .mp4
Snoxxx wrote: Thu Nov 28, 2019 08:50 7.0.5 before reed mp4 are broken in 7.0.5
How the what now?
Snoxxx
Re: 7.0.5 and .mp4
Post by Snoxxx »
it's ok. I will convert all my file
and if i do use .mp4, i downgrade.
I hope that the mp4 reading will come back soon
Re: 7.0.5 and .mp4
Snoxxx wrote: Thu Nov 28, 2019 10:45 it's ok. I will convert all my file
We're working on a fix already, it should be out soon.
