FPS decreasing by time after playing looping clips
robdr
Post by robdr »
Resolume runs solid at 60fps (matching composition) when started at approx 50% GPU usage (GTX1660 Twin X2). FPS starts decreasing over time and video stars to jitter. Restarting Resolume fixes the issue.
Re: FPS decreasing by time after playing looping clips
What does over time mean exactly?
2 minutes, 3 hours, 10 hours?
Which Resolume version are you using, and which nvidia driver?
is your content DXV3 and running on an internal SSD?
robdr
Post by robdr »
After 2 hours. Resolume also eventually crashes. Yes files are DVX3 running from NVME
robdr
Post by robdr »
Resolume v7.0.5 rev67117
robdr
Post by robdr »
nVidia Driver 432.00 DCH
Sounds like this issue: viewtopic.php?f=12&t=19393
