Previsualisation / Planning Tool for Installation - recommendations?
nightjar84
Post by nightjar84 »
Hello
I was wondering wether there is a software for media / video installation previsualisation, i.e. for planning the later installation. Something intuitive like frame forge, but more optimized for video art.
Thanks for the feedack.
Best,
Janis
Re: Previsualisation / Planning Tool for Installation - recommendations?
Look into Capture:
https://www.capture.se/
Empyfree
Post by Empyfree »
I use WYSIWYG. From Cast. You can create surfaces and add NDI sources to them.
Empyfree wrote: Wed Jan 22, 2020 19:06 I use WYSIWYG. From Cast. You can create surfaces and add NDI sources to them.
Look at you with that "Baller" Money $$$$$ ;)
nightjar84
Thanks for the tips.
I also made some further research, anybody using "sketchup" or "shapr3d" (on Ipad). To have a tool on the ipad would be amazing.
2 different tools. sketchup is how you build you environment, capture and wysywig and ma3d is what plays back your lighting and video in those environments.
Jgrover
Post by Jgrover »
Capture Student 2019 allows NDI inputs to be used as textures and its free!
The paid version allows projectors. And it costs money!
Also accepts ArtNet.
gpvillamil
Post by gpvillamil »
Mapping Matter is really good https://www.mappingmatter.com/
However the pricing might be prohibitive.
He2neg
Post by He2neg »
just hear about this on social media...
https://pixelclone.com/software/block-ups/RTStage
"only" 65€
may be worth a look
~Berlin~
Empyfree
Post by Empyfree »
Arvol wrote: Wed Jan 22, 2020 19:26
Luckily I use it for my normal work! Luckier still I don’t pay for it myself!
For static renders I prefer to use SketchUp. Just export a png from Resolume to attach in my model. Still hoping that somebody will come up with a symphony texture plugin for SketchUp!
