Set Random Playback on Entire Composition or Group
weird_design_studio
Post by weird_design_studio »
Is there a way to set a random playback on the entire composition or group in Arena 7?
I want to map it to a momentary piano style key, so that when it's pressed, the playback is random, but when it's released it goes back to normal. This doesn't seem possible any longer in Arena 7. It was something I used frequently. Any ideas or work arounds would be appreciated.
Re: Set Random Playback on Entire Composition or Group
Try mapping all the layer play modes to the same key, Mode set to Random, piano checked.
weird_design_studio
unfortunately, you can only set the Speed, Interval and Distance of Random Playback Mode on each individual "Clip" control, and not on "Layer", "Group", or "Composition" Controls
Also there is no way to set a default for these values (Speed, Interval and Distance ), as far as I can tell. The default values don't achieve the effect I want, and to go through and change them for EVERY clip is way too much work and maintenance.
I understand the added benefit of these speed, interval and distance parameters, but unfortunately it's come at the cost of another feature that was very easy and useful; Random Playback on the Composition
