System crashing overnight
brightpipe
Post by brightpipe »
I've been prepping live and backup PCs for a projection mapping project that we have coming up. I left them running overnight and in the morning Resolume has crashed on both of them.
They are custom built PCs running an i7-4820K and GTX980. The composition uses 3 outputs - 2 at 1920x1200 and 1 3840x1200 into a TripleHead2Go. Both of the systems were using virtual outputs.
I had a 3rd system running in the back that I have been using to do some testing with projectors. It was actually hooked up to 3 projectors so I was only using 1 virtual output. But it didn't crash.
Here is the log from the crash report.
Code: Select all
Resolume Arena 7.1.0 67353 built 17 December 2019
Log started: 25 Feb 2020 11:10:48am
[2020-02-25T11:10:48.053-05:00]   INFO: Logging has started
[2020-02-25T11:10:48.061-05:00]   INFO: Ensuring Nvidia profile correctness
[2020-02-25T11:10:48.279-05:00]   INFO:     Failed adding application Resolume Arena/Arena.exe to custom nvidia profile, it's probably already present
[2020-02-25T11:10:48.285-05:00]   INFO: Nvidia profile setup finished successfully
[2020-02-25T11:10:48.329-05:00]   INFO: Initializing application. Command Line: --IsRestart
[2020-02-25T11:10:48.335-05:00]   INFO:     Initialise JuceResapiApp
[2020-02-25T11:10:48.340-05:00]   INFO:     Initialise ResApi
[2020-02-25T11:10:48.346-05:00]   INFO:     Initializing Resapi
[2020-02-25T11:10:48.351-05:00]   INFO:         Created ParamCollection
[2020-02-25T11:10:48.356-05:00]   INFO:         Created TaskManager with 6 threads.
[2020-02-25T11:10:48.361-05:00]   INFO:         Created InputController
[2020-02-25T11:10:48.367-05:00]   INFO:         Created DeviceChangeDetector
[2020-02-25T11:10:48.372-05:00]   INFO:         Creating VideoFormatManager
[2020-02-25T11:10:48.377-05:00]   INFO:             Registering basic formats
[2020-02-25T11:10:48.384-05:00]   INFO:             Registered 4 formats
[2020-02-25T11:10:48.389-05:00]   INFO:         Created VideoFormatManager
[2020-02-25T11:10:48.406-05:00]   INFO:         Could not create instance of IDeckLinkDiscovery - DeckLink drivers may not be installed or not up-to-date.
[2020-02-25T11:10:48.415-05:00]   INFO:         Creating DisplayCollection
[2020-02-25T11:10:48.424-05:00]   INFO:         Created DisplayCollection
[2020-02-25T11:10:48.430-05:00]   INFO:         First time OpenGL usage, initializing extensions.
[2020-02-25T11:10:48.434-05:00]   INFO:         Registering window class.
[2020-02-25T11:10:48.440-05:00]   INFO:         Successfully registered window class.
[2020-02-25T11:10:48.887-05:00]   INFO:         Successfully initialized extensions.
[2020-02-25T11:10:48.893-05:00]   INFO:         This system supports OpenGL version: 4.1.0 NVIDIA 442.19
[2020-02-25T11:10:48.899-05:00]   INFO:         ---Info main OpenGL renderer---
[2020-02-25T11:10:48.904-05:00]   INFO:         Driver Vendor : NVIDIA Corporation
[2020-02-25T11:10:48.909-05:00]   INFO:         Renderer Name: GeForce GTX 980/PCIe/SSE2
[2020-02-25T11:10:48.914-05:00]   INFO:         Driver Version: 4.1.0 NVIDIA 442.19
[2020-02-25T11:10:48.919-05:00]   INFO:         OpenGL shader language version: 4.10 NVIDIA via Cg compiler
[2020-02-25T11:10:48.923-05:00]   INFO:         Maximum Supported OpenGL version: 4.1
[2020-02-25T11:10:48.928-05:00]   INFO:         -------------------------------
[2020-02-25T11:10:48.933-05:00]   INFO:         Initializing GPUMonitor
[2020-02-25T11:10:48.938-05:00]   INFO:             Trying to create NVApi GPUMonitorStrategy.
[2020-02-25T11:10:48.944-05:00]   INFO:         Successfully initialized GPUMonitor, using NvApi strategy.
[2020-02-25T11:10:48.949-05:00]   INFO:         Initializing renderer.
[2020-02-25T11:10:48.959-05:00]   INFO:             Loading shaders...
[2020-02-25T11:10:49.158-05:00]   INFO:             Successfully loaded shaders.
[2020-02-25T11:10:49.182-05:00]   INFO:         Successfully initialized renderer.
[2020-02-25T11:10:49.212-05:00]   INFO:         Successfully initialized extensions.
[2020-02-25T11:10:49.218-05:00]   INFO:         This system supports OpenGL version: 4.1.0 NVIDIA 442.19
[2020-02-25T11:10:49.223-05:00]   INFO:         Initializing GPUMonitor
[2020-02-25T11:10:49.228-05:00]   INFO:             Trying to create NVApi GPUMonitorStrategy.
[2020-02-25T11:10:49.233-05:00]   INFO:         Successfully initialized GPUMonitor, using NvApi strategy.
[2020-02-25T11:10:49.238-05:00]   INFO:         Initializing renderer.
[2020-02-25T11:10:49.243-05:00]   INFO:             Loading shaders...
[2020-02-25T11:10:49.253-05:00]   INFO:             Successfully loaded shaders.
[2020-02-25T11:10:49.276-05:00]   INFO:         Successfully initialized renderer.
[2020-02-25T11:10:49.305-05:00]   INFO:         Successfully initialized extensions.
[2020-02-25T11:10:49.311-05:00]   INFO:         This system supports OpenGL version: 4.1.0 NVIDIA 442.19
[2020-02-25T11:10:49.315-05:00]   INFO:         Initializing GPUMonitor
[2020-02-25T11:10:49.320-05:00]   INFO:             Trying to create NVApi GPUMonitorStrategy.
[2020-02-25T11:10:49.326-05:00]   INFO:         Successfully initialized GPUMonitor, using NvApi strategy.
[2020-02-25T11:10:49.330-05:00]   INFO:         Initializing renderer.
[2020-02-25T11:10:49.336-05:00]   INFO:             Loading shaders...
[2020-02-25T11:10:49.346-05:00]   INFO:             Successfully loaded shaders.
[2020-02-25T11:10:49.368-05:00]   INFO:         Successfully initialized renderer.
[2020-02-25T11:10:49.374-05:00]   INFO:         Initializing Resapi graphics
[2020-02-25T11:10:49.379-05:00]   INFO:             Initializing GPUMonitor
[2020-02-25T11:10:49.384-05:00]   INFO:                 Trying to create NVApi GPUMonitorStrategy.
[2020-02-25T11:10:49.389-05:00]   INFO:             Successfully initialized GPUMonitor, using NvApi strategy.
[2020-02-25T11:10:49.394-05:00]   INFO:             Initializing TextureUploader
[2020-02-25T11:10:49.399-05:00]   INFO:                 Determining AutoDetect setting
[2020-02-25T11:10:49.403-05:00]   INFO:                     Immutable Buffers supported: true
[2020-02-25T11:10:49.408-05:00]   INFO:                     GPU Monitoring supported: true
[2020-02-25T11:10:49.413-05:00]   INFO:                 AutoDetect would use DMA transfers
[2020-02-25T11:10:49.418-05:00]   INFO:             Successfully initialized TextureUploader
[2020-02-25T11:10:49.423-05:00]   INFO:         Successfully initialized Resapi graphics.
[2020-02-25T11:10:49.428-05:00]   INFO:     Successfully initialized Resapi.
[2020-02-25T11:10:49.433-05:00]   INFO:     Install default PathParser
[2020-02-25T11:10:49.438-05:00]   INFO:     Enumerate fonts
[2020-02-25T11:10:49.703-05:00]   INFO:     Find default fonts
[2020-02-25T11:10:49.709-05:00]   INFO:     Create Application Object
[2020-02-25T11:10:49.715-05:00]   INFO:     Setting up default composition settings.
[2020-02-25T11:10:49.722-05:00]   INFO:     Resapi: setCurrentApplication
[2020-02-25T11:10:49.728-05:00]   INFO:     Init Colour scheme for user interface
[2020-02-25T11:10:49.733-05:00]   INFO:     Create LookAndFeel
[2020-02-25T11:10:49.739-05:00]   INFO:     Set LookAndFeel
[2020-02-25T11:10:49.745-05:00]   INFO:     Set LookAndFeel
[2020-02-25T11:10:49.750-05:00]   INFO:     Disable screen saver
[2020-02-25T11:10:49.755-05:00]   INFO:     Print version info
[2020-02-25T11:10:49.759-05:00]   INFO:     Major Version: 7
[2020-02-25T11:10:49.765-05:00]   INFO:     Minor Version: 1
[2020-02-25T11:10:49.770-05:00]   INFO:     Micro Version: 0
[2020-02-25T11:10:49.776-05:00]   INFO:     Revision: 67353
[2020-02-25T11:10:49.781-05:00]   INFO:     Id: 1
[2020-02-25T11:10:49.786-05:00]   INFO:     Revision string: rev67353
[2020-02-25T11:10:49.791-05:00]   INFO:     Version string with revision: 7.1.0 67353
[2020-02-25T11:10:49.796-05:00]   INFO:     Version string without revision: 7.1.0
[2020-02-25T11:10:49.801-05:00]   INFO:     Print application paths
[2020-02-25T11:10:49.806-05:00]   INFO:     Executable Path: C:\Program Files\Resolume Arena
[2020-02-25T11:10:49.811-05:00]   INFO:     User Documents Path: C:\Users\BrightPipe\Documents\Resolume Arena
[2020-02-25T11:10:49.816-05:00]   INFO:     Default Data Path: C:\Program Files\Resolume Arena\default
[2020-02-25T11:10:49.821-05:00]   INFO:     Common Data Path: C:\ProgramData\Resolume Arena
[2020-02-25T11:10:49.827-05:00]   INFO:     Common Documents Path: C:\Users\Public\Documents\Resolume Arena
[2020-02-25T11:10:49.832-05:00]   INFO:     Preferences Path: C:\Users\BrightPipe\Documents\Resolume Arena\Preferences
[2020-02-25T11:10:49.837-05:00]   INFO:     Media Path: C:\Program Files\Resolume Arena\media
[2020-02-25T11:10:49.843-05:00]   INFO:     Compositions Path: C:\Users\BrightPipe\Documents\Resolume Arena\Compositions
[2020-02-25T11:10:49.848-05:00]   INFO:     Default Presets Path:
[2020-02-25T11:10:49.854-05:00]   INFO:     User Presets Path: C:\Users\BrightPipe\Documents\Resolume Arena\Presets
[2020-02-25T11:10:49.859-05:00]   INFO:     Video Effects Presets Path: C:\Users\BrightPipe\Documents\Resolume Arena\Presets\Video Effects
[2020-02-25T11:10:49.865-05:00]   INFO:     Audio Effects Presets Path: C:\Users\BrightPipe\Documents\Resolume Arena\Presets\Audio Effects
[2020-02-25T11:10:49.870-05:00]   INFO:     Video Sources Presets Path: C:\Users\BrightPipe\Documents\Resolume Arena\Presets\Sources
[2020-02-25T11:10:49.876-05:00]   INFO:     Audio Plugins Path: C:\Program Files\Resolume Arena\plugins\afx
[2020-02-25T11:10:49.883-05:00]   INFO:     Video Plugins Path: C:\Program Files\Resolume Arena\plugins\vfx
[2020-02-25T11:10:49.889-05:00]   INFO:     Previews Path: C:\Users\BrightPipe\AppData\Local\Resolume Arena\previews
[2020-02-25T11:10:49.895-05:00]   INFO:     Layout Presets Path: C:\Users\BrightPipe\Documents\Resolume Arena\Presets\Interface
[2020-02-25T11:10:49.901-05:00]   INFO:     Print system info
[2020-02-25T11:10:49.906-05:00]   INFO:     Operating system: Windows 10
[2020-02-25T11:10:49.912-05:00]   INFO:     OS 64 bit: Yes
[2020-02-25T11:10:49.917-05:00]   INFO:     CPU vendor: GenuineIntel
[2020-02-25T11:10:50.002-05:00]   INFO:     CPU speed: 3666MHz
[2020-02-25T11:10:50.008-05:00]   INFO:     Number of CPUs: 8
[2020-02-25T11:10:50.014-05:00]   INFO:     Memory size: 16323MB
[2020-02-25T11:10:50.019-05:00]   INFO:     System language is: en
[2020-02-25T11:10:50.024-05:00]   INFO:     Locate preferences directory
[2020-02-25T11:10:50.030-05:00]   INFO:     Locate settings file
[2020-02-25T11:10:50.039-05:00]   INFO:     Load Application settings
[2020-02-25T11:10:50.045-05:00]   INFO:     Install languages
[2020-02-25T11:10:50.059-05:00]   INFO:     Set fonts
[2020-02-25T11:10:50.065-05:00]   INFO:     Looking for unicode font
[2020-02-25T11:10:50.071-05:00]   INFO:     Unicode font found is: Lucida Sans Unicode
[2020-02-25T11:10:50.076-05:00]   INFO:     Language file font setting: FontToRenderThisLanguageInWin
[2020-02-25T11:10:50.081-05:00]   INFO:     Language file font base height setting: 0.00
[2020-02-25T11:10:50.086-05:00]   INFO:     Create ApplicationController
[2020-02-25T11:10:50.094-05:00]   INFO:     Creating NDIVideoServerManager
[2020-02-25T11:10:50.099-05:00]   INFO:         Initializing NDI library
[2020-02-25T11:10:50.108-05:00]   INFO:         Successfully initialized NDI library
[2020-02-25T11:10:50.118-05:00]   INFO:     Created NDIVideoServerManager
[2020-02-25T11:10:50.127-05:00]   INFO:     Update Composition List
[2020-02-25T11:10:50.140-05:00]   INFO:     Enumerating Compositions took: 0.00604 seconds
[2020-02-25T11:10:50.145-05:00]   INFO:     Initializing OSC
[2020-02-25T11:10:50.216-05:00]   INFO:     Install Source Preset preprocessor
[2020-02-25T11:10:50.222-05:00]   INFO:     Install Effect Preset preprocessor
[2020-02-25T11:10:50.227-05:00]   INFO:     Install Animation Preset preprocessor
[2020-02-25T11:10:50.233-05:00]   INFO:     Loading Animation presets
[2020-02-25T11:10:50.316-05:00]   INFO:     Create AudioEngine
[2020-02-25T11:10:50.393-05:00]   INFO:     Load AudioEngine settings
[2020-02-25T11:10:50.400-05:00]   INFO:     Load SMPTE settings
[2020-02-25T11:10:50.405-05:00]   INFO:     Setup Effect presets directory
[2020-02-25T11:10:50.411-05:00]   INFO:     Enabling NDI support
[2020-02-25T11:10:50.416-05:00]   INFO:     Setup Source presets directory
[2020-02-25T11:10:50.422-05:00]   INFO:     Creating VideoSourceManager
[2020-02-25T11:10:50.428-05:00]   INFO:     Created VideoSourceManager
[2020-02-25T11:10:50.434-05:00]   INFO:     Create VideoEngine
[2020-02-25T11:10:50.440-05:00]   INFO:     ra::RenderPassManager::scanDirectoryForExtensions: scanning directory 'C:\Program Files\Resolume Arena\plugins\vfx'
[2020-02-25T11:10:50.446-05:00]   INFO:     Done scanning directory, loaded 0 plugin(s) from it.
[2020-02-25T11:10:50.451-05:00]   INFO:     ra::RenderPassManager::scanDirectoryForExtensions: scanning directory 'C:\Users\BrightPipe\Documents\Resolume Arena\Extra Effects'
[2020-02-25T11:10:50.457-05:00]   INFO:     Done scanning directory, loaded 0 plugin(s) from it.
[2020-02-25T11:10:50.462-05:00]   INFO:     Load VideoEngine settings
[2020-02-25T11:10:50.467-05:00]   INFO:     Pass Application name to spout
[2020-02-25T11:10:50.472-05:00]   INFO:     Set thumbnail for capture device sources
[2020-02-25T11:10:50.479-05:00]   INFO:     Initialize video engine
[2020-02-25T11:10:50.489-05:00]   INFO:     Register internal renderpasses
[2020-02-25T11:10:51.319-05:00]   INFO:     Initialize AudioEngine
Attempting to load VST: C:\Program Files\Resolume Arena\plugins\afx\Bitcrusher.dll
Creating VST instance: Bitcrusher
Initialising VST: Bitcrusher (V1.0.0)
Attempting to load VST: C:\Program Files\Resolume Arena\plugins\afx\Distortion.dll
Creating VST instance: Distortion
Initialising VST: Distortion (V1.0.0)
Attempting to load VST: C:\Program Files\Resolume Arena\plugins\afx\EQ-3.dll
Creating VST instance: EQ-3
Initialising VST: EQ-3 (V1.0.0)
Attempting to load VST: C:\Program Files\Resolume Arena\plugins\afx\Flanger.dll
Creating VST instance: Flanger
Initialising VST: Flanger (V1.0.0)
Attempting to load VST: C:\Program Files\Resolume Arena\plugins\afx\HighPass.dll
Creating VST instance: HighPass
Initialising VST: HighPass (V1.0.0)
Attempting to load VST: C:\Program Files\Resolume Arena\plugins\afx\LowPass.dll
Creating VST instance: LowPass
Initialising VST: LowPass (V1.0.0)
[2020-02-25T11:10:51.858-05:00]   INFO:     Create ShortcutManagers
[2020-02-25T11:10:51.863-05:00]   INFO:     Create ShortcutPresetManager
[2020-02-25T11:10:51.869-05:00]   INFO:     Install Shortcut Preset preprocessor
[2020-02-25T11:10:52.000-05:00]   INFO:     Create Composition
[2020-02-25T11:10:52.053-05:00]   INFO:     Register Composition with controllers
[2020-02-25T11:10:52.060-05:00]   INFO:     Create DmxController And Load Settings
[2020-02-25T11:10:52.070-05:00]   INFO:     Initializing ArtNet on adapter ethernet_32769.
[2020-02-25T11:10:52.077-05:00]   INFO:     ArtNet initialization succeeded.
[2020-02-25T11:10:52.082-05:00]   INFO:     Load Fixture Presets
[2020-02-25T11:10:52.092-05:00]   INFO:     Register application specific renderpasses and sources
[2020-02-25T11:10:52.119-05:00]   INFO:     Load video effect presets
[2020-02-25T11:10:52.197-05:00]   INFO:     Load video source presets
[2020-02-25T11:10:52.203-05:00]   INFO:     Load audio effect presets
[2020-02-25T11:10:52.209-05:00]   INFO:     Create MainWindow
[2020-02-25T11:10:52.247-05:00]   INFO:     Create MainComponent
[2020-02-25T11:10:52.254-05:00]   INFO:     Install KeyListener
[2020-02-25T11:10:52.259-05:00]   INFO:     Install MouseListener
[2020-02-25T11:10:52.264-05:00]   INFO:     Create Monitor Panel
[2020-02-25T11:10:52.270-05:00]   INFO:     Create Layer Properties Panel
[2020-02-25T11:10:52.275-05:00]   INFO:     Create Clip Properties Panel
[2020-02-25T11:10:52.281-05:00]   INFO:     Create Composition Properties Panel
[2020-02-25T11:10:52.286-05:00]   INFO:     Create Composition Properties Panel
[2020-02-25T11:10:52.293-05:00]   INFO:     Create Toolbar Panel
[2020-02-25T11:10:52.300-05:00]   INFO:     Create Shortcuts Panel
[2020-02-25T11:10:52.308-05:00]   INFO:     Create File Browser Panel
[2020-02-25T11:10:52.318-05:00]   INFO:     Create Compositions Panel
[2020-02-25T11:10:52.324-05:00]   INFO:     Create Effects Panel
[2020-02-25T11:10:52.330-05:00]   INFO:     Create Sources Panel
[2020-02-25T11:10:52.336-05:00]   INFO:     Create Help Panel
[2020-02-25T11:10:52.341-05:00]   INFO:     Create Layer Group Panel
[2020-02-25T11:10:52.346-05:00]   INFO:     Create Slices Panel
[2020-02-25T11:10:52.351-05:00]   INFO:     Create UI manager
[2020-02-25T11:10:52.363-05:00]   INFO:     Enumerating Compositions took: 0.00096 seconds
[2020-02-25T11:10:52.392-05:00]   INFO:     Install Layout Preset preprocessor
[2020-02-25T11:10:52.398-05:00]   INFO:     Set sparkle update accepted callback
[2020-02-25T11:10:52.403-05:00]   INFO:     Load auto-saved layout
[2020-02-25T11:10:52.459-05:00]   INFO:     Show main window
[2020-02-25T11:10:52.479-05:00]   INFO:     Create ScreenSetupDriver
[2020-02-25T11:10:52.491-05:00]   INFO:     Set ScreenSetup Presets Directory: C:\Users\BrightPipe\Documents\Resolume Arena\Presets\Advanced Output
[2020-02-25T11:10:52.497-05:00]   INFO:     Load ScreenSetup Presets
[2020-02-25T11:10:52.526-05:00]   INFO:     Create AdvancedScreenSetupWindow
[2020-02-25T11:10:52.558-05:00]   INFO:     Set ScreenSetup Advanced Preferences file: C:\Users\BrightPipe\Documents\Resolume Arena\Preferences\AdvancedOutput.xml
[2020-02-25T11:10:52.564-05:00]   INFO:     Enumerate displays and position MainWindow on primary device
[2020-02-25T11:10:52.576-05:00]   INFO:     Init Screen Setup
[2020-02-25T11:10:52.628-05:00]   INFO:     Load Last Screen Setup
[2020-02-25T11:10:52.653-05:00]   INFO:     Install Screen Setup Preset preprocessor
[2020-02-25T11:10:52.659-05:00]   INFO:     Attach screen setup inspector
[2020-02-25T11:10:52.664-05:00]   INFO:     Attach Undo Stack inspector
[2020-02-25T11:10:52.670-05:00]   INFO:     Attach menu to window
[2020-02-25T11:10:52.676-05:00]   INFO:     Create HelpController
[2020-02-25T11:10:52.682-05:00]   INFO:     Load HelpController file
[2020-02-25T11:10:52.694-05:00]   INFO:     Create MidiController
[2020-02-25T11:10:52.700-05:00]   INFO:     Refresh MidiController
[2020-02-25T11:10:52.706-05:00]   INFO:     Load MidiController settings
[2020-02-25T11:10:52.715-05:00]   INFO:     Start MidiController
[2020-02-25T11:10:52.720-05:00]   INFO:     Create renderer
[2020-02-25T11:10:52.726-05:00]   INFO:     Start renderer
[2020-02-25T11:10:52.731-05:00]   INFO:     Main::CompositionLoader::loadStartupComposition: Loading startup composition
[2020-02-25T11:10:52.737-05:00]   INFO:         No composition was loaded from the command line, opening last opened: "C:\Users\BrightPipe\Documents\Resolume Arena\Compositions\Acadia 2020 AAGP.avc"
[2020-02-25T11:10:52.744-05:00]   INFO:         resolume::CompositionManager::loadComposition: Loading composition from content. File: "C:\Users\BrightPipe\Documents\Resolume Arena\Compositions\Acadia 2020 AAGP.avc"
[2020-02-25T11:10:52.750-05:00]   INFO:             Reading composition xml data
[2020-02-25T11:10:52.757-05:00]   INFO:                 Forking composition reading
[2020-02-25T11:10:52.911-05:00]   INFO:                 Composition clearing is done
[2020-02-25T11:10:52.918-05:00]   INFO:                 Done reading params, reading shortcut presets next
[2020-02-25T11:10:53.025-05:00]   INFO:                 Done reading sync data, cleaning up
[2020-02-25T11:10:53.125-05:00]   INFO:             Successfully read composition xml
[2020-02-25T11:10:53.131-05:00]   INFO:             Reading composition state took: 0.37509 seconds
[2020-02-25T11:10:53.137-05:00]   INFO:             Setting composition high quality to: false
[2020-02-25T11:10:53.142-05:00]   INFO:             Default color format is now: RGBA8
[2020-02-25T11:10:53.148-05:00]  ERROR:         Composition loading finished, result: true
[2020-02-25T11:10:53.153-05:00]   INFO:     Loading startup composition finished
[2020-02-25T11:10:53.159-05:00]   INFO: Application successfully initialized
[2020-02-25T11:10:53.165-05:00]   INFO: Initialise took: 4.83001 seconds
[2020-02-25T11:10:53.612-05:00]   INFO: OpenGLCanvas: New context is created
[2020-02-25T11:10:53.618-05:00]   INFO: Initializing GPUMonitor
[2020-02-25T11:10:53.625-05:00]   INFO:     Trying to create NVApi GPUMonitorStrategy.
[2020-02-25T11:10:53.631-05:00]   INFO: Successfully initialized GPUMonitor, using NvApi strategy.
[2020-02-25T11:10:53.637-05:00]   INFO: Initializing renderer.
[2020-02-25T11:10:53.644-05:00]   INFO:     Loading shaders...
[2020-02-25T11:10:53.656-05:00]   INFO:     Successfully loaded shaders.
[2020-02-25T11:10:53.688-05:00]   INFO: Successfully initialized renderer.
[2020-02-25T11:11:04.003-05:00]   INFO: Load Last Screen Setup
[2020-02-25T11:11:04.053-05:00]   INFO: OpenGLCanvas: New context is created
[2020-02-25T11:11:04.060-05:00]   INFO: Initializing GPUMonitor
[2020-02-25T11:11:04.065-05:00]   INFO:     Trying to create NVApi GPUMonitorStrategy.
[2020-02-25T11:11:04.072-05:00]   INFO: Successfully initialized GPUMonitor, using NvApi strategy.
[2020-02-25T11:11:04.077-05:00]   INFO: Initializing renderer.
[2020-02-25T11:11:04.083-05:00]   INFO:     Loading shaders...
[2020-02-25T11:11:04.094-05:00]   INFO:     Successfully loaded shaders.
[2020-02-25T11:11:04.118-05:00]   INFO: Successfully initialized renderer.
[2020-02-25T11:23:21.368-05:00]   INFO: Prepare for shutdown
[2020-02-25T11:23:21.375-05:00]   INFO: Force Stop Recording
[2020-02-25T11:23:21.383-05:00]   INFO: Composition Prepare for Shutdown
[2020-02-25T11:23:21.444-05:00]   INFO: ***
[2020-02-25T11:23:21.455-05:00]   INFO: Shutdown sequence started
[2020-02-25T11:23:21.476-05:00]   INFO: Auto-save layout
[2020-02-25T11:23:21.489-05:00]   INFO: Auto-saving layout
[2020-02-25T11:23:21.507-05:00]   INFO: Clear menu delegates
[2020-02-25T11:23:21.516-05:00]   INFO: Detach Composition Inspector
[2020-02-25T11:23:21.553-05:00]   INFO: Composition Shutdown
[2020-02-25T11:23:21.667-05:00]   INFO: Stop renderer
[2020-02-25T11:23:21.687-05:00]   INFO: Stop Server if running
[2020-02-25T11:23:22.773-05:00]   INFO: Clean up renderer
[2020-02-25T11:23:22.779-05:00]   INFO: Save Application and VideoEngine settings
[2020-02-25T11:23:22.786-05:00]   INFO: Serialize application model
[2020-02-25T11:23:22.792-05:00]   INFO: Serialize video engine
[2020-02-25T11:23:22.798-05:00]   INFO: Serialize audio engine
[2020-02-25T11:23:22.805-05:00]   INFO: Serialize smpte settings
[2020-02-25T11:23:22.811-05:00]   INFO: Create preferences file (config.xml)
[2020-02-25T11:23:22.817-05:00]   INFO: Write preferences XML (config.xml)
[2020-02-25T11:23:22.828-05:00]   INFO: Save animation presets
[2020-02-25T11:23:22.886-05:00]   INFO: Save DMX preferences
[2020-02-25T11:23:22.897-05:00]   INFO: Saving OSC preferences
[2020-02-25T11:23:22.906-05:00]   INFO: Save MIDI preferences
[2020-02-25T11:23:22.915-05:00]   INFO: Clean up UI
[2020-02-25T11:23:22.921-05:00]   INFO: Context will be deleted: monitor
[2020-02-25T11:23:23.145-05:00]   INFO: Save Video Effect Presets
[2020-02-25T11:23:23.173-05:00]   INFO: Save Source Presets
[2020-02-25T11:23:23.231-05:00]   INFO: Locate preferences directory
[2020-02-25T11:23:23.237-05:00]   INFO: Save Screen Setup Simple Settings
[2020-02-25T11:23:23.254-05:00]   INFO: Close screensetup
[2020-02-25T11:23:23.266-05:00]   INFO: Context will be deleted: ScreenSetup
[2020-02-25T11:23:23.391-05:00]   INFO: Save shortcuts and presets
[2020-02-25T11:23:23.398-05:00]   INFO: Stop output shortcut managers
[2020-02-25T11:23:23.403-05:00]   INFO: Clean up LookAndFeel
[2020-02-25T11:23:23.408-05:00]   INFO: Clean up HelpController
[2020-02-25T11:23:23.414-05:00]   INFO: Clean up DmxController
[2020-02-25T11:23:23.421-05:00]   INFO: Clean up MIDIController
[2020-02-25T11:23:23.441-05:00]   INFO: Clean up Compositon
[2020-02-25T11:23:23.447-05:00]   INFO: Clean the UI Factory
[2020-02-25T11:23:23.452-05:00]   INFO: Clean the Composition Object
[2020-02-25T11:23:23.463-05:00]   INFO: Destroying ClipController
[2020-02-25T11:23:23.468-05:00]   INFO: Done destroying ClipController
[2020-02-25T11:23:23.475-05:00]   INFO: Deinitialize AudioEngine
[2020-02-25T11:23:23.481-05:00]   INFO: Clean up Audio Engine
[2020-02-25T11:23:23.507-05:00]   INFO: Clean up Video Engine
[2020-02-25T11:23:23.513-05:00]   INFO: Save shortcuts and presets
[2020-02-25T11:23:23.518-05:00]   INFO: Clean up LookAndFeel
[2020-02-25T11:23:23.523-05:00]   INFO: Clean up HelpController
[2020-02-25T11:23:23.528-05:00]   INFO: Clean up RecordingController
[2020-02-25T11:23:23.533-05:00]   INFO: Clean up ApplicationController
[2020-02-25T11:23:26.423-05:00]   INFO: Clean up FixtureSelection
[2020-02-25T11:23:26.429-05:00]   INFO: Clean up Application Object
[2020-02-25T11:23:26.434-05:00]   INFO: Shutdown JuceResapiApp
[2020-02-25T11:23:26.439-05:00]   INFO: Release ResApi
[2020-02-25T11:23:26.444-05:00]   INFO: Shutdown ResApi
Log started: 25 Feb 2020 11:41:16am
[2020-02-25T11:41:16.959-05:00]   INFO: Logging has started
[2020-02-25T11:41:16.968-05:00]   INFO: Ensuring Nvidia profile correctness
[2020-02-25T11:41:17.185-05:00]   INFO:     Failed adding application Resolume Arena/Arena.exe to custom nvidia profile, it's probably already present
[2020-02-25T11:41:17.191-05:00]   INFO: Nvidia profile setup finished successfully
[2020-02-25T11:41:17.262-05:00]   INFO: Initializing application. Command Line:
[2020-02-25T11:41:17.268-05:00]   INFO:     Initialise JuceResapiApp
[2020-02-25T11:41:17.274-05:00]   INFO:     Initialise ResApi
[2020-02-25T11:41:17.279-05:00]   INFO:     Initializing Resapi
[2020-02-25T11:41:17.285-05:00]   INFO:         Created ParamCollection
[2020-02-25T11:41:17.290-05:00]   INFO:         Created TaskManager with 6 threads.
[2020-02-25T11:41:17.296-05:00]   INFO:         Created InputController
[2020-02-25T11:41:17.302-05:00]   INFO:         Created DeviceChangeDetector
[2020-02-25T11:41:17.307-05:00]   INFO:         Creating VideoFormatManager
[2020-02-25T11:41:17.312-05:00]   INFO:             Registering basic formats
[2020-02-25T11:41:17.329-05:00]   INFO:             Registered 4 formats
[2020-02-25T11:41:17.335-05:00]   INFO:         Created VideoFormatManager
[2020-02-25T11:41:17.360-05:00]   INFO:         Could not create instance of IDeckLinkDiscovery - DeckLink drivers may not be installed or not up-to-date.
[2020-02-25T11:41:17.371-05:00]   INFO:         Creating DisplayCollection
[2020-02-25T11:41:17.384-05:00]   INFO:         Created DisplayCollection
[2020-02-25T11:41:17.396-05:00]   INFO:         First time OpenGL usage, initializing extensions.
[2020-02-25T11:41:17.408-05:00]   INFO:         Registering window class.
[2020-02-25T11:41:17.413-05:00]   INFO:         Successfully registered window class.
[2020-02-25T11:41:17.870-05:00]   INFO:         Successfully initialized extensions.
[2020-02-25T11:41:17.876-05:00]   INFO:         This system supports OpenGL version: 4.1.0 NVIDIA 442.19
[2020-02-25T11:41:17.882-05:00]   INFO:         ---Info main OpenGL renderer---
[2020-02-25T11:41:17.887-05:00]   INFO:         Driver Vendor : NVIDIA Corporation
[2020-02-25T11:41:17.892-05:00]   INFO:         Renderer Name: GeForce GTX 980/PCIe/SSE2
[2020-02-25T11:41:17.897-05:00]   INFO:         Driver Version: 4.1.0 NVIDIA 442.19
[2020-02-25T11:41:17.901-05:00]   INFO:         OpenGL shader language version: 4.10 NVIDIA via Cg compiler
[2020-02-25T11:41:17.906-05:00]   INFO:         Maximum Supported OpenGL version: 4.1
[2020-02-25T11:41:17.911-05:00]   INFO:         -------------------------------
[2020-02-25T11:41:17.916-05:00]   INFO:         Initializing GPUMonitor
[2020-02-25T11:41:17.921-05:00]   INFO:             Trying to create NVApi GPUMonitorStrategy.
[2020-02-25T11:41:17.927-05:00]   INFO:         Successfully initialized GPUMonitor, using NvApi strategy.
[2020-02-25T11:41:17.932-05:00]   INFO:         Initializing renderer.
[2020-02-25T11:41:17.942-05:00]   INFO:             Loading shaders...
[2020-02-25T11:41:17.980-05:00]   INFO:             Successfully loaded shaders.
[2020-02-25T11:41:18.004-05:00]   INFO:         Successfully initialized renderer.
[2020-02-25T11:41:18.032-05:00]   INFO:         Successfully initialized extensions.
[2020-02-25T11:41:18.038-05:00]   INFO:         This system supports OpenGL version: 4.1.0 NVIDIA 442.19
[2020-02-25T11:41:18.043-05:00]   INFO:         Initializing GPUMonitor
[2020-02-25T11:41:18.048-05:00]   INFO:             Trying to create NVApi GPUMonitorStrategy.
[2020-02-25T11:41:18.053-05:00]   INFO:         Successfully initialized GPUMonitor, using NvApi strategy.
[2020-02-25T11:41:18.058-05:00]   INFO:         Initializing renderer.
[2020-02-25T11:41:18.063-05:00]   INFO:             Loading shaders...
[2020-02-25T11:41:18.074-05:00]   INFO:             Successfully loaded shaders.
[2020-02-25T11:41:18.096-05:00]   INFO:         Successfully initialized renderer.
[2020-02-25T11:41:18.125-05:00]   INFO:         Successfully initialized extensions.
[2020-02-25T11:41:18.130-05:00]   INFO:         This system supports OpenGL version: 4.1.0 NVIDIA 442.19
[2020-02-25T11:41:18.135-05:00]   INFO:         Initializing GPUMonitor
[2020-02-25T11:41:18.140-05:00]   INFO:             Trying to create NVApi GPUMonitorStrategy.
[2020-02-25T11:41:18.145-05:00]   INFO:         Successfully initialized GPUMonitor, using NvApi strategy.
[2020-02-25T11:41:18.150-05:00]   INFO:         Initializing renderer.
[2020-02-25T11:41:18.155-05:00]   INFO:             Loading shaders...
[2020-02-25T11:41:18.166-05:00]   INFO:             Successfully loaded shaders.
[2020-02-25T11:41:18.188-05:00]   INFO:         Successfully initialized renderer.
[2020-02-25T11:41:18.194-05:00]   INFO:         Initializing Resapi graphics
[2020-02-25T11:41:18.199-05:00]   INFO:             Initializing GPUMonitor
[2020-02-25T11:41:18.204-05:00]   INFO:                 Trying to create NVApi GPUMonitorStrategy.
[2020-02-25T11:41:18.209-05:00]   INFO:             Successfully initialized GPUMonitor, using NvApi strategy.
[2020-02-25T11:41:18.214-05:00]   INFO:             Initializing TextureUploader
[2020-02-25T11:41:18.219-05:00]   INFO:                 Determining AutoDetect setting
[2020-02-25T11:41:18.224-05:00]   INFO:                     Immutable Buffers supported: true
[2020-02-25T11:41:18.229-05:00]   INFO:                     GPU Monitoring supported: true
[2020-02-25T11:41:18.233-05:00]   INFO:                 AutoDetect would use DMA transfers
[2020-02-25T11:41:18.238-05:00]   INFO:             Successfully initialized TextureUploader
[2020-02-25T11:41:18.243-05:00]   INFO:         Successfully initialized Resapi graphics.
[2020-02-25T11:41:18.248-05:00]   INFO:     Successfully initialized Resapi.
[2020-02-25T11:41:18.253-05:00]   INFO:     Install default PathParser
[2020-02-25T11:41:18.258-05:00]   INFO:     Enumerate fonts
[2020-02-25T11:41:18.411-05:00]   INFO:     Find default fonts
[2020-02-25T11:41:18.417-05:00]   INFO:     Create Application Object
[2020-02-25T11:41:18.423-05:00]   INFO:     Setting up default composition settings.
[2020-02-25T11:41:18.430-05:00]   INFO:     Resapi: setCurrentApplication
[2020-02-25T11:41:18.435-05:00]   INFO:     Init Colour scheme for user interface
[2020-02-25T11:41:18.440-05:00]   INFO:     Create LookAndFeel
[2020-02-25T11:41:18.446-05:00]   INFO:     Set LookAndFeel
[2020-02-25T11:41:18.451-05:00]   INFO:     Set LookAndFeel
[2020-02-25T11:41:18.456-05:00]   INFO:     Disable screen saver
[2020-02-25T11:41:18.461-05:00]   INFO:     Print version info
[2020-02-25T11:41:18.466-05:00]   INFO:     Major Version: 7
[2020-02-25T11:41:18.471-05:00]   INFO:     Minor Version: 1
[2020-02-25T11:41:18.475-05:00]   INFO:     Micro Version: 0
[2020-02-25T11:41:18.480-05:00]   INFO:     Revision: 67353
[2020-02-25T11:41:18.485-05:00]   INFO:     Id: 1
[2020-02-25T11:41:18.490-05:00]   INFO:     Revision string: rev67353
[2020-02-25T11:41:18.495-05:00]   INFO:     Version string with revision: 7.1.0 67353
[2020-02-25T11:41:18.500-05:00]   INFO:     Version string without revision: 7.1.0
[2020-02-25T11:41:18.505-05:00]   INFO:     Print application paths
[2020-02-25T11:41:18.510-05:00]   INFO:     Executable Path: C:\Program Files\Resolume Arena
[2020-02-25T11:41:18.515-05:00]   INFO:     User Documents Path: C:\Users\BrightPipe\Documents\Resolume Arena
[2020-02-25T11:41:18.520-05:00]   INFO:     Default Data Path: C:\Program Files\Resolume Arena\default
[2020-02-25T11:41:18.525-05:00]   INFO:     Common Data Path: C:\ProgramData\Resolume Arena
[2020-02-25T11:41:18.533-05:00]   INFO:     Common Documents Path: C:\Users\Public\Documents\Resolume Arena
[2020-02-25T11:41:18.538-05:00]   INFO:     Preferences Path: C:\Users\BrightPipe\Documents\Resolume Arena\Preferences
[2020-02-25T11:41:18.543-05:00]   INFO:     Media Path: C:\Program Files\Resolume Arena\media
[2020-02-25T11:41:18.549-05:00]   INFO:     Compositions Path: C:\Users\BrightPipe\Documents\Resolume Arena\Compositions
[2020-02-25T11:41:18.554-05:00]   INFO:     Default Presets Path:
[2020-02-25T11:41:18.560-05:00]   INFO:     User Presets Path: C:\Users\BrightPipe\Documents\Resolume Arena\Presets
[2020-02-25T11:41:18.565-05:00]   INFO:     Video Effects Presets Path: C:\Users\BrightPipe\Documents\Resolume Arena\Presets\Video Effects
[2020-02-25T11:41:18.570-05:00]   INFO:     Audio Effects Presets Path: C:\Users\BrightPipe\Documents\Resolume Arena\Presets\Audio Effects
[2020-02-25T11:41:18.576-05:00]   INFO:     Video Sources Presets Path: C:\Users\BrightPipe\Documents\Resolume Arena\Presets\Sources
[2020-02-25T11:41:18.581-05:00]   INFO:     Audio Plugins Path: C:\Program Files\Resolume Arena\plugins\afx
[2020-02-25T11:41:18.587-05:00]   INFO:     Video Plugins Path: C:\Program Files\Resolume Arena\plugins\vfx
[2020-02-25T11:41:18.592-05:00]   INFO:     Previews Path: C:\Users\BrightPipe\AppData\Local\Resolume Arena\previews
[2020-02-25T11:41:18.598-05:00]   INFO:     Layout Presets Path: C:\Users\BrightPipe\Documents\Resolume Arena\Presets\Interface
[2020-02-25T11:41:18.603-05:00]   INFO:     Print system info
[2020-02-25T11:41:18.609-05:00]   INFO:     Operating system: Windows 10
[2020-02-25T11:41:18.615-05:00]   INFO:     OS 64 bit: Yes
[2020-02-25T11:41:18.621-05:00]   INFO:     CPU vendor: GenuineIntel
[2020-02-25T11:41:18.707-05:00]   INFO:     CPU speed: 3695MHz
[2020-02-25T11:41:18.713-05:00]   INFO:     Number of CPUs: 8
[2020-02-25T11:41:18.718-05:00]   INFO:     Memory size: 16323MB
[2020-02-25T11:41:18.723-05:00]   INFO:     System language is: en
[2020-02-25T11:41:18.728-05:00]   INFO:     Locate preferences directory
[2020-02-25T11:41:18.734-05:00]   INFO:     Locate settings file
[2020-02-25T11:41:18.743-05:00]   INFO:     Load Application settings
[2020-02-25T11:41:18.748-05:00]   INFO:     Install languages
[2020-02-25T11:41:18.762-05:00]   INFO:     Set fonts
[2020-02-25T11:41:18.767-05:00]   INFO:     Looking for unicode font
[2020-02-25T11:41:18.773-05:00]   INFO:     Unicode font found is: Lucida Sans Unicode
[2020-02-25T11:41:18.778-05:00]   INFO:     Language file font setting: FontToRenderThisLanguageInWin
[2020-02-25T11:41:18.783-05:00]   INFO:     Language file font base height setting: 0.00
[2020-02-25T11:41:18.788-05:00]   INFO:     Create ApplicationController
[2020-02-25T11:41:18.796-05:00]   INFO:     Creating NDIVideoServerManager
[2020-02-25T11:41:18.801-05:00]   INFO:         Initializing NDI library
[2020-02-25T11:41:18.810-05:00]   INFO:         Successfully initialized NDI library
[2020-02-25T11:41:18.818-05:00]   INFO:     Created NDIVideoServerManager
[2020-02-25T11:41:18.828-05:00]   INFO:     Update Composition List
[2020-02-25T11:41:18.840-05:00]   INFO:     Enumerating Compositions took: 0.00604 seconds
[2020-02-25T11:41:18.846-05:00]   INFO:     Initializing OSC
[2020-02-25T11:41:18.899-05:00]   INFO:     Install Source Preset preprocessor
[2020-02-25T11:41:18.905-05:00]   INFO:     Install Effect Preset preprocessor
[2020-02-25T11:41:18.910-05:00]   INFO:     Install Animation Preset preprocessor
[2020-02-25T11:41:18.916-05:00]   INFO:     Loading Animation presets
[2020-02-25T11:41:18.988-05:00]   INFO:     Create AudioEngine
[2020-02-25T11:41:19.069-05:00]   INFO:     Load AudioEngine settings
[2020-02-25T11:41:19.075-05:00]   INFO:     Load SMPTE settings
[2020-02-25T11:41:19.080-05:00]   INFO:     Setup Effect presets directory
[2020-02-25T11:41:19.086-05:00]   INFO:     Enabling NDI support
[2020-02-25T11:41:19.091-05:00]   INFO:     Setup Source presets directory
[2020-02-25T11:41:19.096-05:00]   INFO:     Creating VideoSourceManager
[2020-02-25T11:41:19.102-05:00]   INFO:     Created VideoSourceManager
[2020-02-25T11:41:19.107-05:00]   INFO:     Create VideoEngine
[2020-02-25T11:41:19.113-05:00]   INFO:     ra::RenderPassManager::scanDirectoryForExtensions: scanning directory 'C:\Program Files\Resolume Arena\plugins\vfx'
[2020-02-25T11:41:19.118-05:00]   INFO:     Done scanning directory, loaded 0 plugin(s) from it.
[2020-02-25T11:41:19.124-05:00]   INFO:     ra::RenderPassManager::scanDirectoryForExtensions: scanning directory 'C:\Users\BrightPipe\Documents\Resolume Arena\Extra Effects'
[2020-02-25T11:41:19.129-05:00]   INFO:     Done scanning directory, loaded 0 plugin(s) from it.
[2020-02-25T11:41:19.134-05:00]   INFO:     Load VideoEngine settings
[2020-02-25T11:41:19.139-05:00]   INFO:     Pass Application name to spout
[2020-02-25T11:41:19.144-05:00]   INFO:     Set thumbnail for capture device sources
[2020-02-25T11:41:19.150-05:00]   INFO:     Initialize video engine
[2020-02-25T11:41:19.157-05:00]   INFO:     Register internal renderpasses
[2020-02-25T11:41:19.936-05:00]   INFO:     Initialize AudioEngine
[2020-02-25T11:41:20.498-05:00]   INFO:     Create ShortcutManagers
[2020-02-25T11:41:20.504-05:00]   INFO:     Create ShortcutPresetManager
[2020-02-25T11:41:20.509-05:00]   INFO:     Install Shortcut Preset preprocessor
[2020-02-25T11:41:20.638-05:00]   INFO:     Create Composition
[2020-02-25T11:41:20.697-05:00]   INFO:     Register Composition with controllers
[2020-02-25T11:41:20.704-05:00]   INFO:     Create DmxController And Load Settings
[2020-02-25T11:41:20.713-05:00]   INFO:     Initializing ArtNet on adapter ethernet_32769.
[2020-02-25T11:41:20.719-05:00]   INFO:     ArtNet initialization succeeded.
[2020-02-25T11:41:20.724-05:00]   INFO:     Load Fixture Presets
[2020-02-25T11:41:20.734-05:00]   INFO:     Register application specific renderpasses and sources
[2020-02-25T11:41:20.761-05:00]   INFO:     Load video effect presets
[2020-02-25T11:41:20.839-05:00]   INFO:     Load video source presets
[2020-02-25T11:41:20.845-05:00]   INFO:     Load audio effect presets
[2020-02-25T11:41:20.852-05:00]   INFO:     Create MainWindow
[2020-02-25T11:41:20.882-05:00]   INFO:     Create MainComponent
[2020-02-25T11:41:20.889-05:00]   INFO:     Install KeyListener
[2020-02-25T11:41:20.895-05:00]   INFO:     Install MouseListener
[2020-02-25T11:41:20.901-05:00]   INFO:     Create Monitor Panel
[2020-02-25T11:41:20.907-05:00]   INFO:     Create Layer Properties Panel
[2020-02-25T11:41:20.913-05:00]   INFO:     Create Clip Properties Panel
[2020-02-25T11:41:20.919-05:00]   INFO:     Create Composition Properties Panel
[2020-02-25T11:41:20.924-05:00]   INFO:     Create Composition Properties Panel
[2020-02-25T11:41:20.931-05:00]   INFO:     Create Toolbar Panel
[2020-02-25T11:41:20.937-05:00]   INFO:     Create Shortcuts Panel
[2020-02-25T11:41:20.945-05:00]   INFO:     Create File Browser Panel
[2020-02-25T11:41:20.957-05:00]   INFO:     Create Compositions Panel
[2020-02-25T11:41:20.963-05:00]   INFO:     Create Effects Panel
[2020-02-25T11:41:20.969-05:00]   INFO:     Create Sources Panel
[2020-02-25T11:41:20.975-05:00]   INFO:     Create Help Panel
[2020-02-25T11:41:20.980-05:00]   INFO:     Create Layer Group Panel
[2020-02-25T11:41:20.985-05:00]   INFO:     Create Slices Panel
[2020-02-25T11:41:20.991-05:00]   INFO:     Create UI manager
[2020-02-25T11:41:21.002-05:00]   INFO:     Enumerating Compositions took: 0.00098 seconds
[2020-02-25T11:41:21.032-05:00]   INFO:     Install Layout Preset preprocessor
[2020-02-25T11:41:21.038-05:00]   INFO:     Set sparkle update accepted callback
[2020-02-25T11:41:21.043-05:00]   INFO:     Load auto-saved layout
[2020-02-25T11:41:21.098-05:00]   INFO:     Show main window
[2020-02-25T11:41:21.118-05:00]   INFO:     Create ScreenSetupDriver
[2020-02-25T11:41:21.131-05:00]   INFO:     Set ScreenSetup Presets Directory: C:\Users\BrightPipe\Documents\Resolume Arena\Presets\Advanced Output
[2020-02-25T11:41:21.137-05:00]   INFO:     Load ScreenSetup Presets
[2020-02-25T11:41:21.163-05:00]   INFO:     Create AdvancedScreenSetupWindow
[2020-02-25T11:41:21.189-05:00]   INFO:     Set ScreenSetup Advanced Preferences file: C:\Users\BrightPipe\Documents\Resolume Arena\Preferences\AdvancedOutput.xml
[2020-02-25T11:41:21.196-05:00]   INFO:     Enumerate displays and position MainWindow on primary device
[2020-02-25T11:41:21.205-05:00]   INFO:     Init Screen Setup
[2020-02-25T11:41:21.213-05:00]   INFO:     Load Last Screen Setup
[2020-02-25T11:41:21.239-05:00]   INFO:     Install Screen Setup Preset preprocessor
[2020-02-25T11:41:21.245-05:00]   INFO:     Attach screen setup inspector
[2020-02-25T11:41:21.251-05:00]   INFO:     Attach Undo Stack inspector
[2020-02-25T11:41:21.256-05:00]   INFO:     Attach menu to window
[2020-02-25T11:41:21.263-05:00]   INFO:     Create HelpController
[2020-02-25T11:41:21.268-05:00]   INFO:     Load HelpController file
[2020-02-25T11:41:21.283-05:00]   INFO:     Create MidiController
[2020-02-25T11:41:21.289-05:00]   INFO:     Refresh MidiController
[2020-02-25T11:41:21.295-05:00]   INFO:     Load MidiController settings
[2020-02-25T11:41:21.304-05:00]   INFO:     Start MidiController
[2020-02-25T11:41:21.310-05:00]   INFO:     Create renderer
[2020-02-25T11:41:21.316-05:00]   INFO:     Start renderer
[2020-02-25T11:41:21.321-05:00]   INFO:     Main::CompositionLoader::loadStartupComposition: Loading startup composition
[2020-02-25T11:41:21.326-05:00]   INFO:         No composition was loaded from the command line, opening last opened: "C:\Users\BrightPipe\Documents\Resolume Arena\Compositions\Acadia 2020 AAGP.avc"
[2020-02-25T11:41:21.334-05:00]   INFO:         resolume::CompositionManager::loadComposition: Loading composition from content. File: "C:\Users\BrightPipe\Documents\Resolume Arena\Compositions\Acadia 2020 AAGP.avc"
[2020-02-25T11:41:21.341-05:00]   INFO:             Reading composition xml data
[2020-02-25T11:41:21.348-05:00]   INFO:                 Forking composition reading
[2020-02-25T11:41:21.513-05:00]   INFO:                 Composition clearing is done
[2020-02-25T11:41:21.519-05:00]   INFO:                 Done reading params, reading shortcut presets next
[2020-02-25T11:41:21.630-05:00]   INFO:                 Done reading sync data, cleaning up
[2020-02-25T11:41:21.729-05:00]   INFO:             Successfully read composition xml
[2020-02-25T11:41:21.736-05:00]   INFO:             Reading composition state took: 0.38862 seconds
[2020-02-25T11:41:21.741-05:00]   INFO:             Setting composition high quality to: false
[2020-02-25T11:41:21.747-05:00]   INFO:             Default color format is now: RGBA8
[2020-02-25T11:41:21.752-05:00]  ERROR:         Composition loading finished, result: true
[2020-02-25T11:41:21.758-05:00]   INFO:     Loading startup composition finished
[2020-02-25T11:41:21.763-05:00]   INFO: Application successfully initialized
[2020-02-25T11:41:21.769-05:00]   INFO: Initialise took: 4.50025 seconds
[2020-02-25T11:41:22.218-05:00]   INFO: OpenGLCanvas: New context is created
[2020-02-25T11:41:22.225-05:00]   INFO: Initializing GPUMonitor
[2020-02-25T11:41:22.231-05:00]   INFO:     Trying to create NVApi GPUMonitorStrategy.
[2020-02-25T11:41:22.236-05:00]   INFO: Successfully initialized GPUMonitor, using NvApi strategy.
[2020-02-25T11:41:22.241-05:00]   INFO: Initializing renderer.
[2020-02-25T11:41:22.247-05:00]   INFO:     Loading shaders...
[2020-02-25T11:41:22.257-05:00]   INFO:     Successfully loaded shaders.
[2020-02-25T11:41:22.281-05:00]   INFO: Successfully initialized renderer.
[2020-02-25T11:41:27.324-05:00]   INFO: Load Last Screen Setup
[2020-02-25T11:41:27.374-05:00]   INFO: OpenGLCanvas: New context is created
[2020-02-25T11:41:27.380-05:00]   INFO: Initializing GPUMonitor
[2020-02-25T11:41:27.386-05:00]   INFO:     Trying to create NVApi GPUMonitorStrategy.
[2020-02-25T11:41:27.391-05:00]   INFO: Successfully initialized GPUMonitor, using NvApi strategy.
[2020-02-25T11:41:27.397-05:00]   INFO: Initializing renderer.
[2020-02-25T11:41:27.402-05:00]   INFO:     Loading shaders...
[2020-02-25T11:41:27.414-05:00]   INFO:     Successfully loaded shaders.
[2020-02-25T11:41:27.438-05:00]   INFO: Successfully initialized renderer.
[2020-02-25T11:41:36.475-05:00]   INFO: ra::RegistryKey::openLocalMachineKey: Successfully opened key 'SYSTEM\CurrentControlSet\Enum\HID\VID_04D9&PID_A04F&MI_00\8&dbb280e&0&0000'
[2020-02-25T11:41:36.489-05:00]   INFO: ra::RegistryKey::openLocalMachineKey: Successfully opened key 'SYSTEM\CurrentControlSet\Control\Class\{4d36e96b-e325-11ce-bfc1-08002be10318}'
[2020-02-25T11:41:36.497-05:00]WARNING: ra::getDeviceCategory: Cannot get category, 'Keyboard' class name is not recognised.
[2020-02-25T11:41:36.504-05:00]   INFO: ra::MessageWindow::MsgProc: Device of unknown type got disconnected.
[2020-02-25T11:41:36.511-05:00]   INFO: ra::RegistryKey::openLocalMachineKey: Successfully opened key 'SYSTEM\CurrentControlSet\Enum\HID\VID_04D9&PID_A04F&MI_00\8&dbb280e&0&0000'
[2020-02-25T11:41:36.519-05:00]   INFO: ra::RegistryKey::openLocalMachineKey: Successfully opened key 'SYSTEM\CurrentControlSet\Control\Class\{4d36e96b-e325-11ce-bfc1-08002be10318}'
[2020-02-25T11:41:36.526-05:00]WARNING: ra::getDeviceCategory: Cannot get category, 'Keyboard' class name is not recognised.
[2020-02-25T11:41:36.532-05:00]   INFO: ra::MessageWindow::MsgProc: Device of unknown type got disconnected.
[2020-02-25T11:41:36.539-05:00]   INFO: ra::RegistryKey::openLocalMachineKey: Successfully opened key 'SYSTEM\CurrentControlSet\Enum\HID\VID_04D9&PID_A04F&MI_01&Col01\8&161c15b4&0&0000'
[2020-02-25T11:41:36.546-05:00]   INFO: ra::RegistryKey::openLocalMachineKey: Successfully opened key 'SYSTEM\CurrentControlSet\Control\Class\{4d36e96f-e325-11ce-bfc1-08002be10318}'
[2020-02-25T11:41:36.555-05:00]WARNING: ra::getDeviceCategory: Cannot get category, 'Mouse' class name is not recognised.
[2020-02-25T11:41:36.565-05:00]   INFO: ra::MessageWindow::MsgProc: Device of unknown type got disconnected.
[2020-02-25T11:41:36.572-05:00]   INFO: ra::RegistryKey::openLocalMachineKey: Successfully opened key 'SYSTEM\CurrentControlSet\Enum\HID\VID_04D9&PID_A04F&MI_01&Col01\8&161c15b4&0&0000'
[2020-02-25T11:41:36.579-05:00]   INFO: ra::RegistryKey::openLocalMachineKey: Successfully opened key 'SYSTEM\CurrentControlSet\Control\Class\{4d36e96f-e325-11ce-bfc1-08002be10318}'
[2020-02-25T11:41:36.585-05:00]WARNING: ra::getDeviceCategory: Cannot get category, 'Mouse' class name is not recognised.
[2020-02-25T11:41:36.593-05:00]   INFO: ra::MessageWindow::MsgProc: Device of unknown type got disconnected.
[2020-02-25T11:41:36.599-05:00]   INFO: ra::RegistryKey::openLocalMachineKey: Successfully opened key 'SYSTEM\CurrentControlSet\Enum\HID\VID_04D9&PID_A04F&MI_01&Col02\8&161c15b4&0&0001'
[2020-02-25T11:41:36.606-05:00]   INFO: ra::RegistryKey::openLocalMachineKey: Successfully opened key 'SYSTEM\CurrentControlSet\Control\Class\{745a17a0-74d3-11d0-b6fe-00a0c90f57da}'
[2020-02-25T11:41:36.612-05:00]WARNING: ra::getDeviceCategory: Cannot get category, 'HIDClass' class name is not recognised.
[2020-02-25T11:41:36.618-05:00]   INFO: ra::MessageWindow::MsgProc: Device of unknown type got disconnected.
[2020-02-25T11:41:36.624-05:00]   INFO: ra::RegistryKey::openLocalMachineKey: Successfully opened key 'SYSTEM\CurrentControlSet\Enum\HID\VID_04D9&PID_A04F&MI_01&Col02\8&161c15b4&0&0001'
[2020-02-25T11:41:36.630-05:00]   INFO: ra::RegistryKey::openLocalMachineKey: Successfully opened key 'SYSTEM\CurrentControlSet\Control\Class\{745a17a0-74d3-11d0-b6fe-00a0c90f57da}'
[2020-02-25T11:41:36.638-05:00]WARNING: ra::getDeviceCategory: Cannot get category, 'HIDClass' class name is not recognised.
[2020-02-25T11:41:36.644-05:00]   INFO: ra::MessageWindow::MsgProc: Device of unknown type got disconnected.
[2020-02-25T11:41:36.650-05:00]   INFO: ra::RegistryKey::openLocalMachineKey: Successfully opened key 'SYSTEM\CurrentControlSet\Enum\HID\VID_04D9&PID_A04F&MI_01&Col03\8&161c15b4&0&0002'
[2020-02-25T11:41:36.657-05:00]   INFO: ra::RegistryKey::openLocalMachineKey: Successfully opened key 'SYSTEM\CurrentControlSet\Control\Class\{745a17a0-74d3-11d0-b6fe-00a0c90f57da}'
[2020-02-25T11:41:36.663-05:00]WARNING: ra::getDeviceCategory: Cannot get category, 'HIDClass' class name is not recognised.
[2020-02-25T11:41:36.669-05:00]   INFO: ra::MessageWindow::MsgProc: Device of unknown type got disconnected.
[2020-02-25T12:23:13.569-05:00]   INFO: ra::RegistryKey::openLocalMachineKey: Successfully opened key 'SYSTEM\CurrentControlSet\Enum\HID\VID_04D9&PID_A04F&MI_01&Col02\8&161c15b4&0&0001'
[2020-02-25T12:23:13.584-05:00]   INFO: ra::RegistryKey::openLocalMachineKey: Successfully opened key 'SYSTEM\CurrentControlSet\Control\Class\{745a17a0-74d3-11d0-b6fe-00a0c90f57da}'
[2020-02-25T12:23:13.590-05:00]WARNING: ra::getDeviceCategory: Cannot get category, 'HIDClass' class name is not recognised.
[2020-02-25T12:23:13.597-05:00]   INFO: ra::MessageWindow::MsgProc: Device of unknown type got connected.
[2020-02-25T12:23:13.603-05:00]   INFO: ra::RegistryKey::openLocalMachineKey: Successfully opened key 'SYSTEM\CurrentControlSet\Enum\HID\VID_04D9&PID_A04F&MI_01&Col02\8&161c15b4&0&0001'
[2020-02-25T12:23:13.609-05:00]   INFO: ra::RegistryKey::openLocalMachineKey: Successfully opened key 'SYSTEM\CurrentControlSet\Control\Class\{745a17a0-74d3-11d0-b6fe-00a0c90f57da}'
[2020-02-25T12:23:13.615-05:00]WARNING: ra::getDeviceCategory: Cannot get category, 'HIDClass' class name is not recognised.
[2020-02-25T12:23:13.621-05:00]   INFO: ra::MessageWindow::MsgProc: Device of unknown type got connected.
[2020-02-25T12:23:13.628-05:00]   INFO: ra::RegistryKey::openLocalMachineKey: Successfully opened key 'SYSTEM\CurrentControlSet\Enum\HID\VID_04D9&PID_A04F&MI_01&Col03\8&161c15b4&0&0002'
[2020-02-25T12:23:13.635-05:00]   INFO: ra::RegistryKey::openLocalMachineKey: Successfully opened key 'SYSTEM\CurrentControlSet\Control\Class\{745a17a0-74d3-11d0-b6fe-00a0c90f57da}'
[2020-02-25T12:23:13.641-05:00]WARNING: ra::getDeviceCategory: Cannot get category, 'HIDClass' class name is not recognised.
[2020-02-25T12:23:13.647-05:00]   INFO: ra::MessageWindow::MsgProc: Device of unknown type got connected.
[2020-02-25T12:23:13.653-05:00]   INFO: ra::RegistryKey::openLocalMachineKey: Successfully opened key 'SYSTEM\CurrentControlSet\Enum\HID\VID_04D9&PID_A04F&MI_00\8&dbb280e&0&0000'
[2020-02-25T12:23:13.660-05:00]   INFO: ra::RegistryKey::openLocalMachineKey: Successfully opened key 'SYSTEM\CurrentControlSet\Control\Class\{4d36e96b-e325-11ce-bfc1-08002be10318}'
[2020-02-25T12:23:13.666-05:00]WARNING: ra::getDeviceCategory: Cannot get category, 'Keyboard' class name is not recognised.
[2020-02-25T12:23:13.672-05:00]   INFO: ra::MessageWindow::MsgProc: Device of unknown type got connected.
[2020-02-25T12:23:13.681-05:00]   INFO: ra::RegistryKey::openLocalMachineKey: Successfully opened key 'SYSTEM\CurrentControlSet\Enum\HID\VID_04D9&PID_A04F&MI_00\8&dbb280e&0&0000'
[2020-02-25T12:23:13.688-05:00]   INFO: ra::RegistryKey::openLocalMachineKey: Successfully opened key 'SYSTEM\CurrentControlSet\Control\Class\{4d36e96b-e325-11ce-bfc1-08002be10318}'
[2020-02-25T12:23:13.694-05:00]WARNING: ra::getDeviceCategory: Cannot get category, 'Keyboard' class name is not recognised.
[2020-02-25T12:23:13.700-05:00]   INFO: ra::MessageWindow::MsgProc: Device of unknown type got connected.
[2020-02-25T12:23:13.706-05:00]   INFO: ra::RegistryKey::openLocalMachineKey: Successfully opened key 'SYSTEM\CurrentControlSet\Enum\HID\VID_04D9&PID_A04F&MI_01&Col01\8&161c15b4&0&0000'
[2020-02-25T12:23:13.713-05:00]   INFO: ra::RegistryKey::openLocalMachineKey: Successfully opened key 'SYSTEM\CurrentControlSet\Control\Class\{4d36e96f-e325-11ce-bfc1-08002be10318}'
[2020-02-25T12:23:13.719-05:00]WARNING: ra::getDeviceCategory: Cannot get category, 'Mouse' class name is not recognised.
[2020-02-25T12:23:13.725-05:00]   INFO: ra::MessageWindow::MsgProc: Device of unknown type got connected.
[2020-02-25T12:23:13.732-05:00]   INFO: ra::RegistryKey::openLocalMachineKey: Successfully opened key 'SYSTEM\CurrentControlSet\Enum\HID\VID_04D9&PID_A04F&MI_01&Col01\8&161c15b4&0&0000'
[2020-02-25T12:23:13.738-05:00]   INFO: ra::RegistryKey::openLocalMachineKey: Successfully opened key 'SYSTEM\CurrentControlSet\Control\Class\{4d36e96f-e325-11ce-bfc1-08002be10318}'
[2020-02-25T12:23:13.745-05:00]WARNING: ra::getDeviceCategory: Cannot get category, 'Mouse' class name is not recognised.
[2020-02-25T12:23:13.751-05:00]   INFO: ra::MessageWindow::MsgProc: Device of unknown type got connected.
Any idea what could be going on?
Re: System crashing overnight
brightpipe
Zoltán wrote: Thu Feb 27, 2020 08:12 probably viewtopic.php?f=12&t=19393
but hard to say without the crash log https://resolume.com/support/en/reporti ... rt-a-crash
Unfortunately my machines don't have wifi cards so were offline when they tried to submit them. I do have 3 zipped crash reports. Is there another way to submit them for review?
If the email address field was filled out, you can submit them here: https://app.bugsplat.com/postcrashreport/
If not, please send them to us directly to mail@resolume.com
