R.Arena 6 BPM issue
fred13
R.Arena 6 BPM issue
Post by fred13 »
hello guys,
I did read all the comments elated to this issue, but I'haven't found any solution which works for me.
I do recover the sound from an external microphone. I'm running a PC with Windows 10 and I did change properly the microphone privacy. but in Resolume Arena 6, I can see the FFT Moving according to my external music via the external microphone, but the BPM is static Always 90 BPM (as an example)
into prefernce of R. Arena 6 I did well put the right parameters etc...
I did re install the latest Resolume version as well.
any idea please ?
many thanks in advance
Re: R.Arena 6 BPM issue
I'm afraid Resolume doesn't do BPM detection currently.
You can use the tap button to adapt to the tempo of the music, quickly, or you might be able to find a third party solution which can send the BPM to Resolume directly.
fred13
Post by fred13 »
Oups ! I was not aware about this. Then I might use Ableton maybe ? What do you think ?
Thank you very much for your support
Ableton doesn't do that either as far as I know.
Try Waveclock: http://wavesum.net/products.html
fred13
Post by fred13 »
;) Okey ! Thank you for sharing info.
Then last question what about upgrading Res. 6 to 7 if Resolume 7 does this job ? Does it ?
fred13 wrote: Thu Mar 12, 2020 13:27 Then last question what about upgrading Res. 6 to 7 if Resolume 7 does this job ? Does it ?
I don't think I understand the question...
fred13
Post by fred13 »
is Resolume 7 measure the BPM ? I was thinking to upgarde my resolume 6
fred13 wrote: Thu Mar 12, 2020 17:29 is Resolume 7 measure the BPM ? I was thinking to upgarde my resolume 6
Zoltán wrote: Wed Mar 11, 2020 13:21 Resolume doesn't do BPM detection currently.
fred13
Post by fred13 »
Many thanks for your support. Unfortunately wavelock is only available on Mac not PC
He2neg
Post by He2neg »
Never tested this but i saved it for moments like thiis.
https://www.bigfug.com/software/audiobox/
~Berlin~
