ENTTEC OCTO
Brucehig
ENTTEC OCTO
Post by Brucehig »
Does the ENTTEC OCTO work with Resolume 6?
I know there are issues with the ENTTEC DMX USB Pro talking to Resolume.
I am trying to output to LED Pixel Tape.
The OCTO appears to be working fine in ENTTEC Stand Alone mode.
In my Advanced Output in Resolume the IP address is the same as the OCTO.
Also does not work if my IP is one digit off.
Thank you
Re: ENTTEC OCTO
The Octo supports Art-net, right?
That should work fine with Resolume.
https://resolume.com/support/en/dmx
