Two Launchpad MK2
uezi
Two Launchpad MK2
Post by uezi »
Hello,
i want to use two Launchpad MK2 in Resolume. My Problem... I can not change the Midi Channel. I used the manual for it to change Channel from Novation.
I use an iMac for Software.
Did already used somebody two same Controller?
Re: Two Launchpad MK2
In Resolume 7 they should just work, they can also use the same midi channels.
They should show up with a number behind the name, and then in the shortcuts you can select which controller you'd like to assign: https://resolume.com/support/en/midi-sh ... di-devices
