Comp size - Windows vs Mac
acarracena
Post by acarracena »
I am woking on a comp with 25000(+/-)*768 and 4 outputs.
I have a Clevo P775 with RTX2080 and a HP OMEN and they handle this size but not the 4 outputs so I will use the Macbook Pro Cylinder from the rental company. But it limits the comp to 16384*####.
Is there any way to fix this? Or this is an OS thing...
I know I can divide the the screen but to make it easier for the content creator and for me placing ndi footage that will be receiving where ever they want.
I also bought an TB3 to 2x HMDI 4k to connect to the thunderbolt 3 port on Clevo but it didn't work. The technicians at the clevo shop are looking at the bios etc to see if theres something they can enable to make this work.
Does anyone have any knowledge from any of this 2 things?
Thank you!!!
Re: Comp size - Windows vs Mac
16384 is the maximum texture size your GPU can handle. To change this, you'd need to use a different GPU.
Changing your composition to 12500 x 1536 would be the same amount of pixels (half width, double height) and would work on bot your mac and pc GPUs.
