[FIXED] Record with Alpha
John McGeoch
Post by John McGeoch »
Hi, I`d like the ability to record with alpha (presumably DXV) as well as the standard no alpha stream. This is in order to make loops, features and so forth, especially with plugins like extruder etc. The other option would be to do this by recording the clip / time and then rendering it to DXV with alpha. Resolume is fast and smooth enough now to be a content creator as well as a play out program.
Re: Record with Alpha
You can now do this since version 7.2. Open the Preferences and on the Recording tab you can change the codec to DXV with alpha or even use ProRes for the best quality.
