NDI HX camera app in Resolume Arena 6
lamatastisch
Post by lamatastisch »
How it is possible to use the NDI HX camera app in Resolume Arena 6. Every time when I try it I get the image that I should update my receiver software. I have the latest version of Resolume Arena 6 and the latest version of the NDI HX camera app installed.
Re: NDI HX camera app in Resolume Arena 6
Have you tried to install the NDI HX drivers from Newtek? https://www.newtek.com/ndihx/products/
lamatastisch
Yes
I always get this view:
In the NDI Studio Monitor I can see the image vom the IPad
Hmm, installing the HX drivers worked for us so far.
What you could try would be replacing the ProcessingNDI.dll in the Resolume Arena 6 program folder with this one: https://www.dropbox.com/s/z0rj7289cviqs ... l.zip?dl=1
This is a newer version of the libraries, also bundled with Resolume 7.1.2
lamatastisch
Thanks, with the new library everything works fine!
Awesome! :)
hersch
Post by hersch »
hi, zoltán! i just installed the tools and drivers but i'm still getting the same message. also downloaded the dropbox file but i can't find the file i need to replace in the resolume folder. any advice would be awesome :)
Are you on mac or windows?
hersch
Post by hersch »
mac, version 6. thanks!
Replacing the library on mac will break the application on mac unfortunately, because of code signing.
Are you sure you have the HX drivers installed? http://new.tk/NDIHX-Driver-OSX
Have you tried Arena 7?
