Audioreactive Videoclip Speed
Trig Fardust
Post by Trig Fardust »
I would love to have a connection between the TEMPO OF A VIDEOCLIP AND THE AUDIO! I think about to drive the parameter from a audiosignal to the speed of a videoclip. I would love to have possibilities to make a clip faster/slower in connection with a audiosignal...
He2neg
Re: Audioreactive Videoclip Speed
Post by He2neg »
How do you want it to work...
Loud = fast
Silent = slower / stop ?
I think you can mapp the "speed" parameter to react to the incoming audio (fft)
Or some other magic you want to happpen ?
~Berlin~
Trig Fardust
Exactly
Louder = faster
Silent = stop, slower
would be so good!
Can i make this already?
He2neg
Post by He2neg »
Trig Fardust wrote: Sun Jun 14, 2020 11:02 Exactly
Louder = faster
would be so good!
yes... ;) take a look at how to set up audio reactiv effects.... you can use audio in to manipulate all different parameters and this include the parameters in the "transport" section.
Little Triangle on the left of the parameter -- chose audio fft -- change the settings as you like...
~Berlin~
Trig Fardust
Yes i know how i can make parameters react to audio. But in the Transport i cant make anything reactive. There is no little arrow aviable. In the clip mode not and cant find it in layer or composition mode. Can you explain how i can do it in the transport?
Thanks for your feedback
He2neg
Post by He2neg »
You are right... i just checked and its not piossible to set the speed of the clip to audio reactiv... strange i was sure it was possible. :ugeek:
what you can do is use the master speed of the composition... this is linkable to the audio fft...
Mhm... maybe some1 from the resolum team can jump in and tell us if it was possible or why its not....
~Berlin~
Trig Fardust
Thank you for your fast response - it would be supernice to set the clup speed to audio!
deflost
Post by deflost »
it was possible in resolume 1 and 2
after this they take it away!
in resolume 1 and 2 were a example clip with a guy and a very big hammer, it was a loop.
he hits on stones.
we used it a lot with the fft to playhead feature.
why is it gone. there were several discussions here before about this.
why is it gone, the feature?
there was no answer till now.
thx.
r.h.
westfernsehen, leipzig
Sam Pauwels
Post by Sam Pauwels »
I'm looking at the exact same problem. Is anything fixed already?
Is there a way to make the transport property of a clip audioreactive?
I have a video with stills on every frame and would love to have it randomly jump in it's timeline connected to the audiovalue. If a certain volume is reached on a certain frequency, jump to another random frame.
It is said that it was possible in the early versions of Resolume, and with the IR ClipSa plugin. Why is this not supported now? @Resolume WHY?
cheerz
Sam
Ciandoeslights
Post by Ciandoeslights »
I was gonna drop a plugin on juicebar that will do this for Yee :) looks like a few of yous want it. What should it be called? Audio reactive transport?
