Ctrl+Shift+1/2/3 on AZERTY keyboard
nopbm
Post by nopbm »
This is my fisrt post. I tried searching by myself for a few hours but still get stuck with my problem.
When set as AZERTY (its normal mode since I'm in France), my keyboard seems to be unable to send the Ctrl+Shift+1/2/3 combination, to enter Fullscreen mode.
The only way I found is to set it as QWERTY especially for Resolume but it's a pain in the ass when I try to search for a media, an effect, or want to use my personnal shortcuts...
Did anyone find a trick ?
To developpers, maybe adding the Ctrl + Shift + &/é/"/'/ could be awsome shortcut aliases for AZERTY users.
Re: Ctrl+Shift+1/2/3 on AZERTY keyboard
Interesting.
Made a ticket, we'll see what we can do.
Are you using the symbols or the numbers more often on your keyboard?
nopbm
Post by nopbm »
I guess symbols would be the best solution since it doesn't involve cap locking.
Thank you !
