Show movies with Arena 6
lamatastisch
Post by lamatastisch »
I have to show movies (1,5 to 2h) with Arena 6 and the video jumps. With shorter clips I never had a problem. Currently the movies are in mp4 containers. What can I do?
He2neg
Re: Show movies with Arena 6
Post by He2neg »
Decode them into dxv ;) or prores codec.
Other way would be to use vlc mediaplayer and route the output with ndi inside arena.
~Berlin~
lamatastisch
What is the best (I am on an windows maschine)? I tried dxv and the filesize was 15-times bigger, is this normal?
He2neg
Post by He2neg »
lamatastisch wrote: Fri Jul 10, 2020 14:36 What is the best (I am on an windows maschine)? I tried dxv and the filesize was 15-times bigger, is this normal?
yes it is....dxv files are bigger becouse on so hard compressed...
Best results in stability you get wiht dxv or prores codec inside a .mov container.
when you dont want to have such huge files, or not the time to recode the videos then the best solution would be to stream it into resolum with an external player (vlc / ndi )
~Berlin~
