Atem Mini or Mini Pro?
Does the [basic] Atem Mini support multiple live-simultaneous feeds into Resolume or is that only a function of the Pro version
Re: Atem Mini or Mini Pro?
Both...only give you 1 of the input signals via usb....
i mean....both only send the program via usb.... the programm can be a pip ... but you cant get hdmi 1-2-3&4 into resolum at the same time... you need to switch
with the atem mini (switcher)
~Berlin~
~Berlin~
Like He2neg said.... both..mini and pro can only give you one feed into resolume via usb-c. But with the Pro version you have the option to also use the HDMI Output and feed it into Resolume via another HDMI capture device. On the Pro you can choose via button what goes out to the HDMI port. M/V PGM PRV cam 1-4
Do you like outlines? Easy Outliner on Juicebar
