It would be helpful to be able to add tags/ Keywords for medias and use it to search/filter media
it could be a local Database and have also the possibility to write them as metadata within the media itself to share or carry when you plan on a machine with other presets . or when you just rearrange your media library to different drives .
it could also be useful to have a cloud tag off all media imported to a composition or when you clic on the composition list you have a quick glance at keywords used
add tags/ Keywords to media
vectorfuton
Re: add tags/ Keywords to media
Color coding (with more than 6 colors) would be cool too. And/or Emoji integration! Ableton introduced this feature a few versions ago and it actually helps me out a lot. Would be great to maintain visual consistency across software.
