blocks/groups in Advanced Output
Godzil
Post by Godzil »
would be useful the possibility of joining few slices in one block for further manipulating. now we have to select slices one by one to just move them or something. and to select them again and again to make something else
Re: blocks in Advanced Output
I'm not following? In Advanced Output I typically have 10-30 "dummy" screens with no output but just various creatively placed slices. Then inside of Resolume I just drag a screen into slice transform to get the look I want. Is this not what you're sort of looking to do?
You mean slice grouping?
Godzil
Post by Godzil »
Zoltán wrote: Mon Nov 23, 2020 17:14 You mean slice grouping?
Yep. locking few selected slices in one group/block.
Re: blocks/groups in Advanced Output
Wouldn't it be easier to duplicate those slices in a new screen and then just drag in the screen, rather than grouping or locking slices inside the slice menu? Also having them in their own screen gives you the ability to change position and size on the fly if you need it
Godzil
Post by Godzil »
Arvol wrote: Tue Nov 24, 2020 17:33
i'm not getting the same results using slices as with advanced output on one screen. maybe i'm not managing slices that well, maybe missing something. but for now AO is more comfortable for me.
It should be 1:1. I would just copy and paste your slices you want to group into a new screen. since it's a copy and paste everything should be 1:1.
If you would like me to make a small video demonstrating this, I could get to that later on today. lmk :)
Godzil
Post by Godzil »
would be interesting
Here's a quick video on how to group slices using dummy screens in advanced output. Hope this helps :)
https://vimeo.com/483197549
Godzil
Post by Godzil »
i'll check it. thanks
